メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
Why my speakers stopped working?
Hi. I bought a used Macbook Pro M1 2020 used one, apparently in very good condition and great battery and all. After 1 week of usage the speakers stopped working, but Headphones jack is working fine, I tried to clean it up and but no luck. Tried all other troubleshooting steps, even opened it up and reconnected the flex cables but nothing happened. Before speakers stopped working there was very little crackling sound coming sometimes. So should I get speakers replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Sounds like the Audio board needs replacing. Review Apples service guide here 13” MacBook Pro M1.
このアンサーは役に立ちましたか?
スコア 1
24 件のコメント:
Hi Dan, thanks for the reply. Could you please help me with the part number I could find 923-05048/49, this is the audio flex assembly, it's should be replaced?
Regards
さんによる
Hey Dan, the tech guy called he says some audio section is not working meaning the audio signal is not reaching to the speakers, and he mentioned they'd need to do some "programming" that will format the macbook. Is it right? Please help
さんによる
@alichaudhary - Something is odd here… The speakers and headset socket are analog signals, not digital!
There is no programming other than the volume and balance controls which alters the DAC logics output to the speakers which you can control via the sound preferences settings.
Think of it this way… Your Stereo system outputs are analog to its speakers, the amp offers the controls. Some expensive speakers offer a tuning bridge to bias the bass and treble the speaker unit offers. This is all analog circuits.
Apple often mixes functions. This cable offers the headset jack and within it there is a set of switches which moves the analog output between the headset jack and the speakers.
さんによる
Thanks for your response Dan. So I will tell them not to format/reset my Macbook, correct? They will replace the audio board and hopefully that will bring back the sound, otherwise speakers could faulty, yes?
さんによる
@alichaudhary - A single speaker I could see or both speakers where blown by over driving them.
The volume level and the deep beats in some music can kill your speakers! This is often what people encounter with their stereos when they try to fill a large space for an event with home systems.
So did you push your system too hard? Then I could see the speakers dying! More likely the switch within the socket got messed up. I’ve see a lot more switches failing than speakers.
They don’t need to wipe your drive or alter the OS. If they do you will loose what was on your system. Apps and your data! Unless you backup and have been good about it.
さんによる
19件以上のコメントを表示
コメントを追加
回答を追加する
Ali Chaudhary さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 26
今までの合計 696
