メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ford Focusの第2世代モデル。
windshield washer pump not working
replacing pump
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
Rick, you need to know how to replace the pump?
さんによる 共有
Yes
さんによる 共有
just follow the instructions in the Answer :-) good luck
さんによる 共有
Not sure which model Focus this applies to, but on my 2005 Focus wagon, the "remove the washer reservoir" stage was considerably more involved than described. The write-up by 'jim1fun1' captured the added complexity on my vehicle which included unbolting the AC receiver dryer for clearance to un-clip the two AC lines blocking the upper, front reservoir bolt. (And the clip must be drilled out, then re-riveted during reassembly.)
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
To remove the pump and reservoir, follow this:
Remove the windshield washer reservoir filler neck.
Raise and support the vehicle.
Remove the right-hand fender splash shield
Remove the washer reservoir.
Disconnect the electrical connectors.
Pull off the hoses.
Remove the windshield washer pump with rubber gasket
Disconnect the electrical connector.
Disconnect the hoses.
Lift out the pump.
Vehicles with headlamp washer system
Remove the headlamp washer pump and rubber seal.
Lift out the pump.
Installation
NOTE: When installing the reservoir, the filler neck must be inserted using Vaseline.
To install, reverse the removal procedure.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thanks A Millon
さんによる 共有
you are welcome :-) good luck
さんによる 共有
コメントを追加
My car was the ZX3 2 door hatch back but probably all body styles have the reservoir in the same location. First this is not an easy job and will probably cost a few bucks to get a mechanic to do it. If you are going to do this yourself the first part that should come off is the filler neck under the hood. Mine was a bear but if you spray some silicone down where the neck pushes into the reservoir after you remove the bolt. you can work the filler neck back and forth to get the silicone down around the bushing then take two pair of vice grips and clamp them one the neck and pullllll. You have to remove the right (passenger side) front wheel and remove the inner fender liner. The push pins on the liner can't be just pulled out. You have to pry and screw out the center of the pin before you can remove the body from the hole. Once the inner fender is down there are two bolts that hold the reservoir in. One is down at the bottom near the pump and the other is up at the top under the AC hoses that run along the top of the inner fender. You can pop the lines loose to remove the bolt but that won't get you enough room to move the pump to a position where you can remove it. You will have to unbolt the AC bottle that the lines go to and also drill out the rivet that holds the AC lines at the top inside the inner fender. This will give you enough room to move the reservoir forward to remove the pump. Caution: use a screw driver to remove the stuck on hoses to the pump. They are usually almost welded on the fittings. Now you have to determine if the it's the pump or wiring. Run a test light that is long enough to reach the battery and the pump connector. On my vehicle there is a two way pump. There are two hoses coming off the bottom of the pump. One for the windshield and one for the rear hatch. The pump spins in opposite directions to wash one or the other. That being said, when someone holds the washer switch for the windshield one terminal on the washer connector is positive and one is negative. If you push the washer switch for the rear window the connector terminals switch polarity, so your positive is now negative (ground) and the other is now hot, positive. So that means to test the connector for ground the switch has to be depressed in the car to make the connection. If you determine that you are getting power and ground to the pump, it's time to get a new one. Check inside where the pump pushes into the grommet for the fluid to make sure the screen inside isn't clogged. Get your new pump and lube everything with silicone to facilitate getting everything together. Check your new pump to make sure it works by putting the electrical connector on first and trying it. Note, it wouldn't hurt to put some dielectric compound on the connector to help eliminate corrosion. Put your rear washer hose on next.
Once the back hose and wiring are on the pump, lube the reservoir grommet and pump nipple and push the pump into the reservoir. Now connect your other pump hose. At this point I would line up the upper grommet with the hole in the fender a put in a little washer fluid to make sure nothing leaks and the pump pumps fluid before I put everything back together. I don't know about you but I'm lazy, I hate doing stuff twice cause I got in a hurry.... Once everything seems to be working fine reverse the removal procecure. Bolt the reservoir back in and then the AC canister. Pop rivet the hose retainer back to the top of the inner fender well and reattach your hoses. Then the filler neck needs put back on. Don't forget to silicone the grommet and the filler neck to get it to go in easier. Then install your inner fender liner and the front wheel. PS: make sure you torque you lugnuts on the wheel. The spec is in your owners manual under changing the spare tire. Good Luck. A fifteen dollar pump will probably cost you about $100.00 by a mechanic.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Bruce, I replaced my 07' Ford freestyle washer pump. You must first remove radiator reservoir, don't drain fluid, unplug electrical plug and just unbolt it and push to the right out of the way. It is located beside the washer fluid tank. Then unbolt tank. Unplug electrical plug from front and unplug electrical plug from pump on middle lower side, then disconnect hoses from pump . Make sure you wash out tank. Insert new rubber filter and pop in new pump thru rubber garment. Install all hoses, side plug to washer pump. Attach tank and electrical plug. Reattach radiator tank and electrical plug and you are done, great job.
さんによる 共有
Nice write-up: my 2005 Focus wagon came apart just as you detailed for removing the reservoir. (I.e., unbolting the AC receiver dryer for clearance to unclip the two AC lines blocking the upper, front reservoir bolt. Plus drilling out and re-riveting the clip.) Thanks!
さんによる 共有
Thank you for your thorough description of the operation of the pump- especially about how the pump motor spins in a forward or reverse direction to spray either the windshield or the rear window. I also appreciate your recommendation of applying a lubricant to the grommet and motor inlet prior to installation to facilitate ease of installation and to forestall the possibility of leaks from less than optimal fitment. Most videos of pump replacement online omit this important step. Concern remains about filtration of the fluid to prevent blockage of hoses or nozzles with crud. Some pictures I have seen online show a filter sleeve attached to the grommet, or a coarse filter on the pump inlet. Most replacement pumps come with a grommet but fail to show clearly how the fluid is filtered. Your thoughts?
さんによる 共有
コメントを追加
回答を追加する
Rick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 44
今までの合計 25,521
