Mac Classic II Harddrive replacement
Here's a grand folly: Has anyone ever tried to replace the original SCSI harddrive with a SATA, or even a SSD SATA??? Adapters and not enough space come to mind....
I don't see any SATA adapters for this machine, but there are a few SCSI to SD adapters.
A few I've found are:
BlueSCSI (reply for information on where to buy)
If you're not in the US, let me know in a comment and I can send you links to purchase these products in your region.
このアンサーは役に立ちましたか?
Mmm… This is a bit of a puzzle! SCSI was a great system! But it’s performance peaked! I have never seen or heard of a SCSI to SATA solution, I wish there was! I have a collection of JAZZ 2TB drives which I would love to use for backups again.
I’m sure someone could create such a converter, I doubt it would fit or could be powered by the internal PS.
The trick is to get a SCSI PCI board to get the SCIS chip and support chips as well as a SATA to PCI then using a micro-controller to drive the PCI logic and move the signal across. This requires some serious micro code for the controller.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 31
今までの合計 1,085
4 件のコメント
@andrewsawesome - Sorry no SD or CF slot in this series.
DanJ さんによる
@johns21588 let's give it a try. Working on one right now and let me see if an adapter and a SSD will fit. Ordering the adapter as we speak so hopefully, I have some in-depth details for your next week. Everything is just academics unless we give it a try.
oldturkey03 さんによる
I'm largely curious about what effect it would have on Startup, and regular running of applications saved to the 'hard drive'. Capacity is not a big deal, since the original hard drives were only 80MB max.
It would also be interesting to see how difficult it is to install an operating system on a standalone Mac like this with a solid state drive of some sort internal.
John S さんによる
I don't know if this will help, but just wanted to point out that dosdude1 has recently made an IDE SSD (https://github.com/dosdude1/2.5-inch-ide...). Don't know how hard it would be to adapt this to SCSI, but just wanted to point it out.
Andrew S さんによる
