メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
214回答 すべてを表示
Can I add a ssd hard drive when it seems to have never had a hd?
To begin, I’m mechanical but not incredibly computer-savvy.
I have an i5 late 2012 emc2544 21.5” iMac. It has been running fine but I have run out of room. It said it has a 64gb hard drive.
I bought a 1tb ssd upgrade kit from ifixit and opened it up tonight. I was surprised to see no drive in the slot. I’m unfamiliar with all of the terms used and just trying to figure out if I can add this drive to my system as an internal hard drive or if I have to put it into an external case and just use it like that.
I’ve seen things that make me think I can get cables and add it but I’m just not sure.
Update (02/02/2023)
There is no hard drive in the little compartment.
I hope this picture comes through
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Can you take a picture of your current drive posting it here for us to see and point us to what you bought so we have a better idea.
Update (02/06/2023)
OK, I think I get it where’s the drive?? Well hidden!
Your system came with a blade SSD which is mounted on the backside of the logic board. Review this guide iMac Intel 21.5インチ EMC 2544 ブレードSSDの交換
So I would leave it be and just add in a second drive following this guide iMac Intel 21.5インチ EMC 2544 のハードドライブの交換. You will need to get these two cables Data cable and Power cable
Update (02/07/2023)
@jfryjfry - Here’s the drive connectors on the back side which I circled.
iMac Intel 21.5" EMC 2544 ハードドライブの画像
ガイド
難易度:
中レベル
25 minutes - 1 hour
iMac Intel 21.5" EMC 2544 ブレードSSDの画像
ガイド
難易度:
中レベル
2 hours
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Added a pic to the initial post. Thanks for taking a look.
I put it back together to check what it says it has and it has 250gb flash storage. So I’m guessing it never had an actual hard drive. Can I add one???
さんによる
I’m cautiously optimistic… I see no place to plug the two cables onto the board and the installation procedure obviously shows them already in position because that one came with them.
I haven’t taken the board out and cannot see underneath it but I can’t imagine there are two open slots. Or should there be??
さんによる
Parts ordered! I’ll update when I pull it apart (again!)
さんによる
コメントを追加
回答を追加する
Jeremy fry さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 89
