keyboard typing wrong letter.
my keyboard is 1st player dk 5.0 gaming keyboard. just your average tkl gaming keyboard. the problem on my keyboard is that the number on the keyboard is shuffled up and giving the wrong input.
example:
the sequence for the number is 1234567890. on my keyboard, its 1638923450
idk if you can understand this but basically
if i press 2 it typed 6, if i press 8 it typed 4, press 9 it typed 5 and vice versa
the only working number is only 1,3,0. if you realised, number 3 shows up twice. that because the key for 3 and 7 inputted the same number which is 3. also, only numbers that were affected by this and the other keys were fine.
some things you may need to know:
- when this happen, i may looked youtube and downloaded sharpkey that play with the registry editor.
- during on like administrator setting or something where it basically ignore 3rd party stuff or something, the keyboard worked absolutely fine. the numbers were typed giving the correct input and etc. as if there was a filter on my computer that giving the wrong input on my computer.
any help given is appreciated
この質問は役に立ちましたか?
6 件のコメント
Does this still happen on a different computer?
Duck さんによる
@thequacker i dont know since i dont have accesss to other computer
kelaydeck さんによる
Check the keyboards driver setting are you using the correct mapping (language)
Dan さんによる
@cempehduck Does it work if you start your computer in safe mode? It's only the numbers that are affected? Are you using a Windows computer? What version?
oldturkey03 さんによる
@oldturkey03 sorry for a very late reply. never tried safe mode. only numbers affected. windows 10
kelaydeck さんによる
1以上のコメントを表示
