Guidance on Screen replacement
How much more difficult does “touch screen” function make replacement? Are there many more caveats to screen replacement?
@eeandersen it is not much more difficult. You will just have a few more cables and connectors. Essentially the same work. You can download the maintenance and service guide for the HP Pavilion x360 14m-cd0005dx from here It'll guide you through the repair
このアンサーは役に立ちましたか?
@eeandersen, On your laptop the touch screen function is integrated into the LCD display, so there isn't any separate part to deal with; in fact, you can't replace them separately. As @oldturkey03 mentioned, there will be one more connector to route and plug in for the digitizer, but that's it for the difference between replacing your display and a simple LCD replacement.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 300
