メインコンテンツにスキップ
モデル番号A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544回答 すべてを表示
Boot to Blank Screen
can anyone provide any assistance?!?!
I have used this guide a few times now to successfully replace screens however I have an early 2011 17" MBP that now boots to a white screen and that is it, cannot boot in recovery or safe mode. It even turns off a few seconds after starting up. Any thoughts on what could be causing this issue?
I have double-checked all connections and cannot see what the issue could be, I did also upgrade RAM as there was one empty slot as well as put in a new hard drive. I have done this type of upgrade before but have never run into this issue. Any advice would be greatly appreciated.
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sadly this sounds like a blown GPU chip which is quite common in this series.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Dang, that's unfortunate... minus a few dead pixels in the display the computer was working fine before attempting to switch the screen.
Thank you for your response Dan!
さんによる
コメントを追加
回答を追加する
acacella7 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 26
