メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox Wireless Controllerの第3世代モデル。2020年11月にXbox Series XおよびSeries Sに同梱されてリリースされました。このコントローラーは、これまでのXbox OneコンソールやPCと後方互換性があります。
Problem with LT and RT always pressed
The left and right trigger always keep pressed, this problem began when i replace(
solder and desolder) both stick, first right stick and the controller works normally but when i replace the left stick the problem began.
This video show better the problem(this is the official xbox app): https://1drv.ms/v/s!AhpypwlrW5KohIBgdkgz... as you see the lt and rt button keeps pressed but the others works normally and this is another video with other app(the problem is more visible with this): https://1drv.ms/v/s!AhpypwlrW5KohIBhcMTA...
Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
最も参考になった回答
I just came across this problem on LT and fixed the problem by replacing the U11 component (303 hall effect sensor for the trigger) with an old xbox one controller 304 hall effect sensor.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Just wanted to say thank you for this! I didn’t need to replace it but reflowing this chip fixed the issue for me! I wouldn’t have even known to touch this component had it not been for your comment.
さんによる 共有
@stuffmonster I'm glad I was able to help someone with this solution. One less controller in the bin. 😎
Thank you!
さんによる 共有
コメントを追加
Check U9 controller on a board. On output should be 1.4V. I have a solution but it's not very nice. Connect output trace with 3.3V. It worked for me but I don't guarantee that it will work for a long time. You could also replace this IC. Problem is that it's a very small piece and it is easy to burn using hotait. Sometimes this IC doesn't have any specifications on it (especially in 1708 and older) so proper resoldering it can be quite tough
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
do you mean inject voltage on the trace to fix it?
さんによる 共有
Yes. It helped. I don't remember where specifically I connected it, it was a long time ago. Maybe before a voltage divisor if there was. I remember that those sensors have common power so if there is no power, they both don't work.
さんによる 共有
コメントを追加
WERE you able to fix it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If anyone encounter problem with LT and RT trigger always pressed, replace U9 controller, for me it worked, and I even used U9 chip from Xbox One controller and soldered into Xbox Series Controller and yes it worked if someone was wondering.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
rafaeljevi さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 60
過去 30 日: 230
今までの合計 5,781
