メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年3月に発売されたSamsungのフラッグシップAndroidスマートフォン、Samsung Galaxy S20の修理および分解情報。
Screen touch after glass replacement?
I have an S20 I want to repair. the screen is cracked and does not have touch in certian areas. Will I have to replace the whole screen or just the glass?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi Jenna,
While it is possible to replace just the front glass, that doesn't address the problems with the digitizer you're having, as the two parts are separate. In addition, doing so requires special equipment and skills so as not to damage the OLED display, and a laminating machine is needed to bond the new glass to the LCD. Suffice to say that front glass replacement is beyond the capabilities of us home DIYers.
So that leaves us with replacing the screen assembly, and there you have two choices, with or without a frame attached.
The LCDs that come with the frame requires you to transfer all of the internal parts of the phone to the new frame, so it ends up being a lot of work.
With the ones that don't come with a frame, you have to carefully separate the old LCD from the existing frame and glue the new screen to the frame. It's a bit harder to get the old screen off, but you don't have to do all the parts transferring involved in replacing a frame.
Either way, there are guides available here on iFixit that will step you through the process from beginning to end. In order to replace it you'll need the model number, as there appear to be two different screens depending on whether it's a Verizon model or not.
Guide for screens with the frame (assumes the battery comes with it, but depending where you buy it, it may not).
Galaxy S20 Screen and Battery Assembly Replacement - iFixit Repair Guide
Here's the guide to use if you buy just the LCD without the frame.
Samsung Galaxy S20 Screen Replacement - iFixit Repair Guide
You can get the screen with the frame here on iFixit, or with or without it at several other vendors such as Amazon, eBay or AliExpress; whatever works for you.
Hope this helps, let us know how it goes.
Galaxy S20 スクリーンの画像
ガイド
Samsung Galaxy S20 スクリーンの交換
難易度:
難しい
45 minutes - 2 hours
Galaxy S20 スクリーンとバッテリーアセンブリの画像
ガイド
Galaxy S20 スクリーンとバッテリーアセンブリの交換
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Replace the screen with a new frame attached. Piece of cake to do, no faffing with removing the screen from the frame and trying to glue the new one in properly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jenna Williams さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 7
過去 30 日: 18
今までの合計 1,040
