メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第3世代のApple iPad(4G対応)の修理ガイド、分解、トラブルシューティング情報です。ストレージ容量は16 GB、32 GB、64 GBから選択可能です。2012年3月発売。モデル番号A1430(GSM、AT&T)またはA1403(CDMA、Verizon)で識別されます。修理には熱を加え、慎重にこじ開ける作業が必要です。
Why is it not charging?
So basically I haven't used my iPad in about 2 years or so. I recently found it in my drawer. I tried charging it and sometimes it gets to the low battery and black background screen. I left it for about 2 hours or so, and it didn't work, so I tried another charger, and it still didn't work.
TL;DR: Found my old iPad, put it in charge and it didn't work, even with a different charger (waited for around 2 hours).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@xsinqq replace the battery. It is most likely discharged below its threshold iPad 3 4G バッテリーの交換
さんによる
コメントを追加
3件の回答
It is incredibly common for the charge port to be dirty.
Try cleaning it (carefully) with a toothpick or a toothbrush and some alcohol preferably isopropyl.
That said there's still a good chance it's the battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Are you using a charger with at least 2a output? Phone chargers are useless for iPads. Also after two years the battery may be beyond help. Maybe could do with a new one if you want it working again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If it has been sitting idle for some number of years it would not be unheard of for the battery to be worn out. Lithium Ion batteries don’t like being left dead for long periods of time and is so discharged it just isn’t functional any longer.
Make sure when its charging you have it connected to the original charger, or one rated for at least 10 watts. If it is an Apple charger it will say on the brick. Otherwise wattage is Voltage x Amperage. iPads can take a good hour to power on from that level of dead if they are going to power on at all.
If that doesn’t work, then a new battery is in order.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shubhankar Shreyash さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 24
今までの合計 379
