メインコンテンツにスキップ
The Toyota Tundra is a pickup truck manufactured in the United States by Toyota.
18回答 すべてを表示
2000 Toyota Tundra Limited 4.7L issue
I’m trying to troubleshoot-diagnose my 2000 Toyota Tundra Limited 4.7L issue.
The engine shuts off when I put it into gear ⚙️ D or R; but, stays on in N.
I’ve been told via mobile mechanic it’s possibly a bad solenoid in transmission or torque converter/throttle plate.
Searching websites and DIY on YouTube.
Please advise any directional arrows you might know!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
I suggest searching Toyota Tundra forums with members owning and sharing info. They may be more experienced in answering TT problems unless a resident expert here with TT expertise can answer this question.
さんによる
Thank you 😊- ok, Toyota Tundra Forums! Do you know of any such Forums? —IF so, please post a Link in your reply! 🧰⚙️🔧
さんによる
Thanks 🙏🏼 again.. I will surf’m for insights upon my profit walk! —Cheers!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I'm guessing the transmission is locked up. Putting it into gear stalls the engine because it can't turn the torque converter.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
So, iF torque converter can’t work, what has to be actually done to “UNLOCK” it? Specifying how much labor and parts do I need to BUDGET for? Thx for your time and profitable directional arrows! 🤑
さんによる
コメントを追加
回答を追加する
Jays2000ToyotaTundra さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 66
