メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
371回答 すべてを表示
Keeps turning off and wont turn on for a while
I have a Macbook Air A1466 (mid-2012). Looks like it's working fine, but after some time using it (can be one day, or just one hour) it turns off and won't turn on again for few hours.
Everything looks fine with it, except for this problem, that turned it into a useless notebook. Power adapter looks like working fine (battery charges and discharges normally).
I already tried to reinstall OS and change power adapters.
Follows attached the Coconut Battery information:
The built-in diagnostic shows me the error PPT004, but I read that it shows this error for non-apple batteries... I replaced the battery recently and was working fine.
What could be wrong with it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
さんによる
@danj Thanks. I added Coconut's image on the question.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
OK, the battery looks healthy! As far as PPT004, this often is related to SMC needing a reset after a new battery.
Lets give this a try, follow this guide to disconnect the battery go to Step 3 MacBook Air 13インチ Mid 2012バッテリー交換 With the battery disconnected press and hold the power button for 15sec to fully discharge the logic board, now plug the MagSafe charger in, the system should spontaneously restart, let it finish booted and then do a proper shutdown. Reconnect the battery and restart the system give it a good 15 mins to let the systems settings to reset, then restart and run the onboard diagnostics again did that clear the PPT004 error?
Update (08/23/2022)
Sorry we need to start replacing things to fix this system. I'm suspecting your trackpad is the hot issue MacBook Air 13" (Mid 2012) Trackpad and here's the MacBook Air 13インチ Mid 2012 トラックパッドの交換 guide.
I think you have a moisture issue which is what is messing you up. I would inspect the logic board as it might also have some corrosion as well.
MacBook Air 13" (Mid 2012) Trackpadの画像
製品
$94.99
MacBook Air 13" Mid 2012 バッテリーの画像
ガイド
難易度:
中レベル
15 minutes
MacBook Air 13" Mid 2012 トラックパッドの画像
ガイド
難易度:
中レベル
50 minutes - 2 hours
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Thanks for the instruction.
I did it but still PPT004 shows on diag and the computer problem still persists.
(FYI: diag also says the camera have problem NDC001, but I think it's not related)
さんによる
@Fernando Ŝajani - I was hoping it would be a simple fix, sadly not. The SMC logic is having problems! Did you have a liquid spill into the keyboard/trackpad or sit the system down on a wet surface at some point?
This will need the logic board repaired or replaced.
さんによる
@danj I dont remember spilling any liquid on it. I usually use it on my desk. I took to an technical guy to take a look at the logic board, but he could not find anything. Probably he doesn't have enough expertise to properly diagnose the problem. :(
さんによる
@Fernando Ŝajani - Do you use a cleaner spray on your keyboard/trackpad? That could be the issue!
さんによる
@danj No, I never did that... Should I?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Fernando Ŝajani さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 51
