メインコンテンツにスキップ
2022年2月25日に発売されたValve製の携帯ゲーム機「Steam Deck」の修理・分解・トラブルシューティング情報です。型番1010で識別されます。
253回答 すべてを表示
Which screw do I need for metal plate?
Hi, yesterday I upgraded my SSD in the steam deck, worked without problems, unfortunately I lost the top left screw from the metal plate (which you have to remove to disconnect the battery and replace the SSD) I just can't find it, maybe it's even somewhere in the deck, but I wiggled super hardcore and nothing fell off.
So... I want a screw in there, it works without it, but I don't know if that's good. Has anyone any idea what screw I need?
Update (08/02/2022)
Btw my bought screw (M1.6 x 3mm DIN 965) fits perfectly
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
See the Chosen Solution to this question
Also see Step.5 of the ifixit Steam Deck バッテリーの交換 guide to find the screw sizes and location for the 3 Philipshead screws required to secure the shield. Not sure if they are Philips #0 or Philips #1 though.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Hello, thank you.
I actually found this answer yesterday. But I can't find a screw like this to buy anywhere. M1.6x3mm 0,35 Pitch.. :(
さんによる
@Sebastian Bruhns
Search online for M1.6 x 0.35p Metric Coarse Zinc countersunk Phillips 3mm screw (example only) to find suppliers that suit you best. (click on "Choose an option" to see screw lengths available)
さんによる
I should mention, that I live in Germany. I don't want to wait for shipping over a month or so. Haha. (and I really don't find any screws like this in germany...)
I don't even know if it's really that bad, that this one screw is missing.
In the picture from step5 battery replacement, it's the top left screw. The plate sit pretty flush, just not super tight there, but I think under the Heatshield there are thermal pads, they should make good contact.
さんによる
Or I should say... I did find some screws, but I don't know if the pitch is right. Or is it always the same? idk
Ok, I think I found something. DIN 965 M1.6x3
I did order it. Hopefully this will work.
さんによる
@Sebastian Bruhns
Pitch can vary as it is the distance between each thread in the screw.
This can also be known as TPI (threads per inch). Basically the number of threads along the shaft of the screw per given distance.
Sometimes screws may be called coarse or fine. Again this refers to the number of threads. Coarse are usually used in wood or thin metal and fine for thicker metals or if a stronger screw is needed.
If the pitch is too big, and if the hole that the screw is screwed into is a threaded hole with a smaller "pitch" (it already has threads that the screw would screw into easily if they were both the same size), it may not screw in too easily or perhaps it may cut its own thread as you screw it in
Hopefully i haven't confused you further.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Sebastian Bruhns さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 838
