メインコンテンツにスキップ
Sony digital still camera model DSC-H50, February 2008, 3.0" tilting LCD, 9.1 MP CCD, Zoom 15x (31-465mm), f/2.7-4.5
Viewfinder not working, LCD is okay. How to repair?
My Sony DSC-H50's viewfinder does not illuminate when I switch from LCD to viewfinder mode. All other functions work, including the external LCD display. Does anyone know of a repair guide or video? My searches have turned up nothing.
EDIT: After posting this yesterday I did see the viewfinder flash (illuminate) briefly several times, but not in any reproducible way and not when I tried to switch to viewfinder mode. Seems most likely it is a loose connector.
EDIT2: I have attached the Sony repair manual (to the camera info page), but it doesn't really list steps, so I'm hesitant to dive in.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Have you tried disconnecting any unnecessary modules and testing ? I have encountered a similar issue on some canon cameras when the flash module was shorted
さんによる
Thanks, HIF. This camera has no accessories/modules attached.
さんによる
@hypercaff hey, I think you misunderstood me. I’m taking about the built in flash module which is present in this model.
さんによる
You're right, I did misunderstand you. The flash module works fine. I haven't disconnected it because I haven't yet figured the right way to disassemble the camera.
さんによる
@hypercaff this service manual should help.
Good luck !
https://www.manualslib.com/manual/125436...
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
I got the camera apart (Thank you, @how_its_fixed!) and found that the ribbon cable between the main board and the viewfinder has several broken traces as shown below. For perversity's sake, pics were taken with the camera itself.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
It appears that flex was laying against something that got hot. That looks like it is burned. Replacing the cable should work, just make sure it is not touching what caused that.
さんによる
I have the same problem today with the EVR of my Sony alpha 58 DSLR. Thankfully, I was able to see your post. This gives me a lead to how I can fix my camera. But then, how do you call this ribbon?
さんによる
@josemarievillas This type cable is called a "flex cable", and, in this case, I assume it would be called the "viewfinder flex cable," or something similar.
さんによる
コメントを追加
最も参考になった回答
Most cameras have a button to switch between LCD and viewfinder. You didn't say that you tried that or that it is suppose to be both on.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks, Bill. This camera only allows use of either the viewfinder or the LCD, and when I switch to viewfinder the viewfinder remains dark.
さんによる
コメントを追加
回答を追加する
Hypercaff さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 41
今までの合計 2,162
