メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech UE Boom 2は、360度のサウンドで知られる防水ポータブルBluetoothスピーカーです。Boom 2には、鮮やかな色やパターンが多数用意されています。
Why my speaker is not powered?
Hello guys,
First of all I'm not an english native speaker so sorry for the mistakes.
Couples year ago my UE BOOM 2 fell into sea water and it didn't work anymore, when I get home I just put it in rice and and it stayed in for a very long time. 2 days ago I tried to charge it (there is the blinking white light) and to turn it on and it worked for like 30 seconds I was able to put music and then it turned off saying that there was no more battery. Basically every time I plug it and I wait a bit I can turn it on during few seconds. I managed to unplug the battery (Li-ion 3.6V 3200mAh) and tested it with a voltmeter. It says that the battery voltage is 4V, then I concluded that the battery was fine and there was an issue with the powering of the speaker. My questions are : have you ever seen something like this ? Do you have any advices about the pieces I should test or replace ? Does anyone know how to fix it ?
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You should look at the PCB inside of the speaker as well as any connected terminals. Since it fell into Sea water I suspect that there is major corrosion going on despite the rice.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eliott Guira さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 279
