メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Creality Ender 3 Proの修理情報。Creality製のEnder 3 3Dプリンターのアップグレード版です。2018年9月発売。モデル番号:Ender 3 Pro。
3D printer blue screen
Built printer, then it turned on. Leveled the plate to the print Nozzle with a piece of paper. I printed 2 test models then a 5 hour model. All 3 models we fine. Then turned off printer. The next day I turned the printer on and only got a Blue screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
10 件のコメント:
was the printer bumped at all?
さんによる 共有
No.
I did a puzzle tube print which took 5 hrs, when it was done I turned the printer off. The next day when it turned it on it had the blue screen.
さんによる 共有
ok, check the connections maybe. there is one on the back of the LCD and another inside the CPU
さんによる 共有
Are you using octoprint or an SD card to print your models? Try using octoprint instead on an SD card, I accidently inserted the wrong SD card and it corrupted the firmware. Try re-flashing the firmware , that usually did the trick the few times it happened to me. On one occasion the LCD connector was loose. good luck.
さんによる 共有
I checked all the connections before hand and then went through a lot of different things that others have said to do., nothing helped.
I just don't know what else it could be. It is brand NEW. I just got it and did 1 print job, turned it off after it was finished, next morning turn it on and got the blue screen.
さんによる 共有
5件以上のコメントを表示
コメントを追加
1 件の回答
its 1 of 3 things u have a loose LCD or not connected properly it could be that u have attempted to mess with the power management by accident and now it's has too much/&or to little voltage and is ether broken or not working properly, or 3 it's something on the board that's needs replacing these are the most common things i run into
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Frank Lovash さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 28
今までの合計 4,255
