メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年に発売されたモノクロレーザープリンターです。印刷速度は35PPMで、最初の1ページ目は8秒で出力されます。所有しているモデル(a/n/dw/dn/dne)によって、オプションや利用可能な機能が異なります。 HP 80A/80Xトナーカートリッジを使用します。
Is this printer work past Catalina?
I have had this printer for 10 years and I have been very happy with it over the years, but my Mac is aging and I may need to upgrade, while keeping my trusty 2014 Retina in service as well. Part of the reason I have kept this computer in service as long as I have is my mono laser. My color laser doesn't have an issue as I just got it and it's a current model with Catalina support (bravo Lexmark) and will carry over to a new Mac well, but my monochrome laser is kind of a question. While my color laser does mono printing, it isn't proper sharp mono. It is gradient based black output where it only uses the black toner and doesn't deploy the CMY toners. It's still sharp, but it doesn't print like a monochrome only laser does. The mono output from the color Lexmark is fine, but there are times I want the sharpness and low CPP of a pure mono laser.
Has anyone run these in Big Sur and Monterey? If you have, are there any problems I should be aware of?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@nick I don't have that printer personally, so I can't test to verify 100%, but HP states that it supports MacOS Monterey (which I'm currently using on this computer). Latest driver release was Jan. 27th, this year.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
My 2014 Retina stops at Big Sur, so I can run one more release and that's it. Once Big Sur is dead, I'm stuck.
さんによる
@nick I have the same with a 2013 Air. It handles Big Sur alright, but that's it :/
さんによる
@geirandersen I'm holding out on the Big Sur upgrade until I need it, due to HW age plus Lexmark still supports Catalina. Why change until I have to?
I was actually questioning if I needed a OS upgrade getting that Lexmark lol.
さんによる
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 343
