メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nissan Altimaは、日産自動車が製造するミッドサイズセダンです。1957年に始まったNissan Bluebirdシリーズの系譜を継ぐモデルといえます。
Altim 2006 2.5 - Poor Acceleration
My Altima 2006 2.5 runs perfectly on a flat road but is very lazy while going up a hill.
I have changed the pressure pump, changed all the coils but still the same issue.
Any help??
Secondly, its has a hard starting
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@laminturay have the OBD scanned. It appears that your Altima has difficulty whenever under a load (where it has to work a bit harder) This could be a fuel problem as well as a combustion issue (poor compression etc.) as well as issues with the emission control. There are to many possibilities and we'll need a good starting point.
There are a few things that can be commonly causing this. You would need to check for a clogged air filter, worn spark plugs, dirty mass air flow sensor (MAF), dirty throttle body, clogged fuel filter, bad fuel pump, failed oxygen sensor, and even a clogged catalytic converter. Anything after that would be deeper inside your engine like blown head gasket, bad piston rings, leaking valves etc. As you can see the list can be pretty extensive.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you so much. I will start with the OBD first to see what exactly the issues are.
さんによる 共有
コメントを追加
回答を追加する
Bilal Mohamed Lamin Turay さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 22
今までの合計 737
