メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP 15-db0015dxは、製品番号5ZC06UAで識別できるHP 15シリーズのノートパソコンです。このモデルは2018年に発売されました。
overheating immediately at 90c
Hello everyone.
Please, I would like to give me some help to the following issue.
It's about the laptop HP 15db1027nv.
With pressing power on button, it burns up. CPU fan starts working from the beginning (with power on), and never stops.
Entering Windows, immediately, Core Temp software shows CPU temp at 90C.
And another that can happen:from Windows it may shutdown without any warning abruptly at 10 minutes (it is for sure because of high temp).
And on a power on session, before start loading Windows, a CPU overheating message from BIOS came up for some seconds only, but I didn't read it all. About 6-7 sentences that had to do with notebook overheating.
I cleaned up cpu fan dust (that dust had been turned into fuzz), and replaced cpu thermal compound. But nothing. With power on, cpu immediately goes to 90C.
What seems to be the problem? Can I do something else to fix the problem?
Thank you for your time.
Update (05/01/2022)
I managed from 90C to make it work normally on 40C-45C. Too many programs run on Windows startup. Disabled them, and temperature now is on about 40C.
But now I have another not really problem, but I am trying to find the answer to that. Before disabling startup applications, on the pictures below, you will see that I removed from heat sink base the sticker it had on. I was affected by internet reading, and thought that by removing it, it may helped. Here are the three images:
before (original heat sink base from factory):
​https://ibb.co/MZ4nnfG​​​
after my removal:
​https://ibb.co/qChjDVt​​​
Now, when I apply heat sink, without the sticker, the heat sink base, and I am not sure about that, but it is the most possible, must come into touch with the cpu die, as the arrow in the following image:
​https://ibb.co/pxZZ4P9​​​
If it was possible, of course, I would put the sticker back, but, unfortunately, the sticker, from my trial to remove it, it has been ruffled and cut in two pieces. If it is possible, could you please explain me what that sticker was there for? Maybe it is ok not to be there. It was for some protection? For temperature guarding? For isolation?
But, I would like to give you this element, too. Without the sticker, and disabling startup applications, I had switched on the laptop, and, without working on it, just had it on desktop, I left it on for 4 hours. No problem, and for these 4 hours, the temperature oscillated between 30C-45C.
So, can you explain me about the sticker and if danger or not not having it there?
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Ccould you plase inform us the procedure to Disable the programs on Windows startup. I have the same problem I have disable almost everything but the temperature is still 89C to 93C.
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
@johnyb98 replace the fan completely. Clean all the airducts on your laptop. Do not use your laptop on things like pillows., blankets etc. Let us know if that changes anything.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thank you very much for your answer. Please, and with all respect, because too many opinions about what a fan is, what a heatpipe is, etc. and I have not understood the laptop fan meaning, can you please tell me what a laptop fan is or what are its parts? Or even better, upload a laptop fan image?
Thank you for your time!
さんによる 共有
@johnyb98
Here's the maintenance and service guide, taken from this support webpage for the laptop.
Go to p.56 to view the necessary pre-requisite steps and the procedure to remove the fan, p.57 to remove the heat sink assembly (aka heat pipe, thermal sink assembly etc) or p.58 the heat plate, if yours is a fanless model.
さんによる 共有
@johnyb98
According to p.58 of the maintenance and service guide that I linked above, it mentions that the "thermal material" needs to be thoroughly removed from the surface of the heat sink and that if replacing the heat sink new "thermal material' is provided with the part.
You could just try applying some thermal paste to the heat sink as this will assist in the heat transfer from the CPU to the heat sink.
Do not apply too much! A little bit goes a long way. It is better to have not enough than to have too much and it overflows.
Search online for more info on applying thermal paste.
Usually it is applied to the CPU but if HP was placing thermal material on the heat sink, then I would do that.
さんによる 共有
コメントを追加
回答を追加する
John Eidert さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 27
今までの合計 931
