6 beep problem when I try to open.
Dell Inspiron 3542
Hi,
A 6 beep error code is a video subsystem failure on the motherboard.
Here's a solution that might work, but maybe not, you can only try. If not you will need the schematics for the motherboard to find out what's happened or you have to replace the motherboard.
Here's the owner manual for the laptop, from this Dell support webpage for the laptop which may help as it shows how to access the motherboard etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 620
