メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
20.2 MPセンサーを搭載した、ソニーのハイエンドコンパクトカメラ、RX100シリーズの初代モデルの修理ガイドとサポート情報です。Sony Cyber-shot DSC-RX100は2012年6月に発売されました。
Splashed camera, no power
Fresh water splashed in a river rapid. When I press the power button, a green light briefly lights up, then goes out. Nothing else happens. How can I diagnose and repair?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @akimboorange
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the camera’s operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your camera and then remove the battery as soon as possible from the camera to minimize any further damage.
Then you need to dis-assemble the rest of the camera and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the camera might possibly work correctly again.
Here is a link to a teardown video for the camera, that may be of some help.
If this process seems too daunting, take your camera to a reputable, professional camera repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joe Balachowski さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 44
今までの合計 783
