メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1200回答 すべてを表示
Panic CPU x caller - Reboot every 3 minutes - Charging Port Flex?
I am looking for ideas to help fix a problem I’m having with an iPhone X. Bear with me while I describe the history, what I’ve done so far, and what the current symptoms are.
The customer said he had originally had the screen replaced at a mall kiosk and it worked well for a couple of months but one day it would not turn on. What I actually found was the phone was turning on but the screen had failed and was not turning on. I installed a new screen and all seemed well. I gave it back to the customer in seemingly 100% working condition. A few days later he brought it back to me and said it was rebooting every few minutes.
  1. I tried forcing an update - no change, still rebooted after a few minutes.
  2. I tried a DFU restore - no change, still rebooted after a few minutes.
  3. I googled the issue and found numerous reports about issues with the charge port causing the phone to restart every 3 minutes. I checked and confirmed the phone would reboot after 3 minutes consistently. So I ordered a new charge port flex.
  4. I first tried to temporarily disconnect the original flex in the phone and temporarily connect the new bare charge port flex. Voila, the phone stayed running beyond 3 minutes.
  5. I disassembled the phone, removed the original charge port flex, reinstalled the new charge port and reassembled the phone. Initially the phone seemed to be fixed. But after several hours I noticed it starting to go back to the 3 minute reboot cycle again. Grr. Maybe I damaged it during installation I thought.
  6. I ordered another new part and repeated step 4 and 5 but with greater care. Again, with the new part installed the phone seemed to fixed. This time I set the screen to stay on and started a stop watch. The phone stayed on for over 3 hours so I left it overnight.
  7. In the morning, the phone was BACK TO RESTARTING every 3 minutes!!!
  8. For fun I disconnected the 2nd new flex that was installed in the phone and connected one of the other charge ports that I had swapped out. With only the charge port by itself connected the phone still reboots. Conclusion - the flex is getting damaged somehow just by connecting it to the phone (my theory anyway).
  9. Some posts on here suggested a DFU restore fixed this issue - in my case, it does not. Tried it. No difference.
I dug into the analytics logs and using 3U Tools see that every time it reboots it logs a “Panic CPU x caller” entry.
Here is the detailed text from one of these entries. Has anyone seen this? What can I try next? I’m hesitant to install a third charge port but do have one if need be.
Thanks in advance for your help,
Larry
{"bug_type":"210","timestamp":"2021-11-06 21:28:52.00 -0600","os_version":"iPhone OS 15.1 (19B74)","incident_id":"41C3AD2D-4165-42EE-9166-C156236A84EC"}
"build" : "iPhone OS 15.1 (19B74)",
"product" : "iPhone10,6",
"kernel" : "Darwin Kernel Version 21.1.0: Wed Oct 13 18:16:58 PDT 2021; root:xnu-8019.42.4~1\/RELEASE_ARM64_T8015",
"incident" : "41C3AD2D-4165-42EE-9166-C156236A84EC",
"crashReporterKey" : "d6ac110a82cef07ecd55c818d6c8d79130b244dc",
"date" : "2021-11-06 21:28:52.45 -0600",
"panicString" : "panic(cpu 1 caller 0xfffffff02941f0f4): userspace watchdog timeout: no successful checkins from thermalmonitord since load\nservice returned not alive with context : is_alive_func returned unhealthy : current 7bfffffffff, mask 67fffffffff, expected 67fffffffff. SD: 1 BC: 0 Missing sensor(s): mic1 \nservice: backboardd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: SpringBoard, total successful checkins since load (168 seconds ago): 17, last successful checkin: 0 seconds ago\nservice: mediaserverd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: logd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: thermalmonitord, no successful checkins since load (180 seconds ago)\nservice: runningboardd, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nservice: wifid, total successful checkins since load (180 seconds ago): 19, last successful checkin: 0 seconds ago\nDebugger message: panic\nMemory ID: 0x6\nOS release type: User\nOS version: 19B74\nKernel version: Darwin Kernel Version 21.1.0: Wed Oct 13 18:16:58 PDT 2021; root:xnu-8019.42.4~1\/RELEASE_ARM64_T8015\nKernel UUID: 13E2F321-3388-3B9E-9D68-75E2081A4A02\niBoot version: iBoot-7429.42.2\nsecure boot?: YES\nPaniclog version: 13\nKernel slide: 0x000000001ff0c000\nKernel text base: 0xfffffff026f10000\nmach_absolute_time: 0x469c3b9d4\nEpoch Time: sec usec\n Boot : 0x61874726 0x000e1526\n Sleep : 0x00000000 0x00000000\n Wake : 0x00000000 0x00000000\n Calendar: 0x618747de 0x00067b28\n\nZone info:\nForeign : 0xfffffff108e0c000 - 0xfffffff108e1c000\nNative : 0xffffffe000460000 - 0xffffffe600460000\nReadonly : 0 - 0\nMetadata : 0xffffffeb0234c000 - 0xffffffeb06770000\nBitmaps : 0xffffffeb03b4c000 - 0xffffffeb04b34000\nCORE 0: PC=0xfffffff027afe428, LR=0xfffffff027af77b8, FP=0xffffffeb0696bc30\nCORE 1 is the one that panicked. Check the full backtrace for details.\nCORE 2: PC=0xfffffff027bcefec, LR=0xfffffff027bcc64c, FP=0xffffffeb11f73e60\nCORE 3: PC=0xfffffff027bcefec, LR=0xfffffff027bcc64c, FP=0xffffffeb11fe3e60\nCORE 4: PC=0xfffffff027ac65c4, LR=0xfffffff027ac65c4, FP=0xffffffeb11f03ef0\nCORE 5: PC=0xfffffff027ac65c4, LR=0xfffffff027ac65c4, FP=0xffffffeb122a3ef0\nTotal cpu_usage: 51279369\nThread task pri cpu_usage\n0xffffffe0f490f038 watchdogd 97 0\n0xffffffe0f5bf52b0 backboardd 63 11205\n0xffffffe0f7b251b8 backboardd 63 0\n0xffffffe0f4783620 thermalmonitord 37 1224\n0xffffffe0f41da958 thermalmonitord 37 932\n\nPanicked task 0xffffffe0f4966df8: 284 pages, 3 threads: pid 57: watchdogd\nPanicked thread: 0xffffffe0f490f038, backtrace: 0xffffffeb0ca5b0c0, tid: 1272\n\t\t lr: 0xfffffff027a96760 fp: 0xffffffeb0ca5b100\n\t\t lr: 0xfffffff027a964f0 fp: 0xffffffeb0ca5b170\n\t\t lr: 0xfffffff027bcd4bc fp: 0xffffffeb0ca5b1f0\n\t\t lr: 0xfffffff027bcc67c fp: 0xffffffeb0ca5b2a0\n\t\t lr: 0xfffffff0281455fc fp: 0xffffffeb0ca5b2b0\n\t\t lr: 0xfffffff027a96208 fp: 0xffffffeb0ca5b640\n\t\t lr: 0xfffffff027a96208 fp: 0xffffffeb0ca5b6a0\n\t\t lr: 0xfffffff02948f5c8 fp: 0xffffffeb0ca5b6c0\n\t\t lr: 0xfffffff02941f0f4 fp: 0xffffffeb0ca5b6e0\n\t\t lr: 0xfffffff02941eae8 fp: 0xffffffeb0ca5b700\n\t\t lr: 0xfffffff0280c023c fp: 0xffffffeb0ca5b760\n\t\t lr: 0xfffffff02941e004 fp: 0xffffffeb0ca5b880\n\t\t lr: 0xfffffff0280ca0fc fp: 0xffffffeb0ca5ba20\n\t\t lr: 0xfffffff027b95128 fp: 0xffffffeb0ca5bb40\n\t\t lr: 0xfffffff027a9bfec fp: 0xffffffeb0ca5bbc0\n\t\t lr: 0xfffffff027a72b60 fp: 0xffffffeb0ca5bcf0\n\t\t lr: 0xfffffff027a89ae8 fp: 0xffffffeb0ca5bd80\n\t\t lr: 0xfffffff027bc1ed8 fp: 0xffffffeb0ca5be60\n\t\t lr: 0xfffffff027bccad0 fp: 0xffffffeb0ca5bf10\n\t\t lr: 0xfffffff0281455fc fp: 0xffffffeb0ca5bf20\n\n",
"panicFlags" : "0x802",
"otherString" : "\n** Stackshot Succeeded ** Bytes Traced 155594 (Uncompressed 410496) **\n",
"memoryStatus" : {"compressorSize":0,"compressions":0,"decompressions":0,"busyBufferCount":0,"pageSize":16384,"memoryPressure":false,"memoryPages":{"active":68803,"throttled":0,"fileBacked":78487,"wired":29225,"purgeable":1193,"inactive":45669,"free":3005,"speculative":23131}},
"processByPid" : {
"0" : {"pid":0,"residentMemoryBytes":153829376,"timesDidThrottle":0,"systemTimeTask":0,"pageIns":0,"pageFaults":1669,"userTimeTask":883.20710391600005,"procname":"kernel_task","copyOnWriteFaults":0,"threadById":{"1146":{"continuation":[0,18328644],"userTime":5.75e-06,"systemTime":0,"id":1146,"basePriority":81,"name":"AppleAOPVoiceTriggerController","user_usec":5,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077513]},"172":{"continuation":[0,18328644],"userTime":0.000100541,"systemTime":0,"id":172,"basePriority":81,"name":"AppleSSE","user_usec":100,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064473]},"142":{"continuation":[0,18328644],"userTime":0.0014304999999999999,"systemTime":0,"id":142,"basePriority":81,"name":"CoreAnalyticsHub","user_usec":1430,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063593]},"528":{"id":528,"schedPriority":81,"system_usec":0,"state":["TH_WAIT"],"schedFlags":["TH_SFLAG_EAGERPREEMPT"],"user_usec":104151,"basePriority":81,"userTime":0.104151458,"waitEvent":[0,39423104],"continuation":[0,12410180],"systemTime":0,"name":"thread call kernel #1"},"654":{"continuation":[0,18328644],"userTime":0.19948874999999999,"systemTime":0,"id":654,"basePriority":81,"name":"IOSurfaceRoot","user_usec":199488,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072793]},"112":{"continuation":[0,18328644],"userTime":0.0073642500000000001,"systemTime":0,"id":112,"basePriority":81,"name":"AppleT8015IO","user_usec":7364,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063273]},"624":{"continuation":[0,18328644],"userTime":1.1041e-05,"systemTime":0,"id":624,"basePriority":81,"name":"AppleCS42L75Audio","user_usec":11,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072633]},"589":{"continuation":[0,13900252],"userTime":4.6659999999999999e-06,"systemTime":0,"id":589,"basePriority":81,"user_usec":4,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41080184]},"720":{"continuation":[0,18328644],"userTime":0.001158708,"systemTime":0,"id":720,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":1158,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074633]},"685":{"continuation":[0,18328644],"userTime":3.8750000000000002e-06,"systemTime":0,"id":685,"basePriority":81,"name":"AppleOLYHAL","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073833]},"1147":{"continuation":[0,18328644],"userTime":1.333e-06,"systemTime":0,"id":1147,"basePriority":81,"name":"AppleSPUProfileFirmwareDriver","user_usec":1,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077593]},"721":{"continuation":[0,18328644],"userTime":0.000758916,"systemTime":0,"id":721,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":758,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074713]},"144":{"continuation":[0,18328644],"userTime":7.5830000000000001e-06,"systemTime":0,"id":144,"basePriority":81,"name":"AppleIPDormancyHandler","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063673]},"656":{"userTime":3.9580000000000001e-06,"systemTime":0,"system_usec":0,"id":656,"basePriority":81,"user_usec":3,"kernelFrames":[[0,12256844],[0,12249632],[0,12168544],[0,16654908],[0,29935324],[0,19138112]],"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41317580]},"722":{"continuation":[0,18328644],"userTime":2.3291000000000001e-05,"systemTime":0,"id":722,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":23,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074793]},"175":{"continuation":[0,18328644],"userTime":6.9999999999999999e-06,"systemTime":0,"id":175,"basePriority":81,"user_usec":7,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064553]},"657":{"userTime":0.0068773749999999998,"systemTime":0,"system_usec":0,"id":657,"basePriority":81,"user_usec":6877,"kernelFrames":[[0,12256844],[0,12249632],[0,12168796],[0,16654832],[0,29951364],[0,19138112]],"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41590016]},"723":{"continuation":[0,18328644],"userTime":0.33504041600000001,"systemTime":0,"id":723,"basePriority":81,"name":"VideoModeMailboxHandler","user_usec":335040,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074873]},"146":{"continuation":[0,18328644],"userTime":7.4580000000000004e-06,"systemTime":0,"id":146,"basePriority":81,"name":"AppleUSBHostResources","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063753]},"272":{"continuation":[0,18328644],"userTime":9.6660000000000003e-06,"systemTime":0,"id":272,"basePriority":81,"name":"AppleSerialShim","user_usec":9,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064953]},"658":{"continuation":[0,18328644],"userTime":2.875e-06,"systemTime":0,"id":658,"basePriority":81,"name":"AppleSMCWirelessCharger","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072873]},"754":{"continuation":[0,18328644],"userTime":2.2910000000000002e-06,"systemTime":0,"id":754,"basePriority":81,"name":"AppleEffaceableBlockDevice","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075033]},"724":{"continuation":[0,18328644],"userTime":0.41496145800000001,"systemTime":0,"id":724,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":414961,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074953]},"177":{"continuation":[0,18328644],"userTime":0.041273333000000002,"systemTime":0,"id":177,"basePriority":81,"name":"AppleKeyStore","user_usec":41273,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064633]},"273":{"continuation":[0,18328644],"userTime":0.000142958,"systemTime":0,"id":273,"basePriority":81,"name":"AppleM2ScalerCSCDriver","user_usec":142,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065033]},"659":{"continuation":[0,18328644],"userTime":3.8330000000000004e-06,"systemTime":0,"id":659,"basePriority":81,"name":"AppleSmartBatteryManager","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072953]},"117":{"continuation":[0,18328644],"userTime":0.032329499999999997,"systemTime":0,"id":117,"basePriority":81,"name":"IOPMrootDomain","user_usec":32329,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063433]},"1149":{"continuation":[0,18328644],"userTime":6.2079999999999997e-06,"systemTime":0,"id":1149,"basePriority":81,"name":"AppleSPUProfileDriver","user_usec":6,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077673]},"340":{"continuation":[0,18328644],"userTime":8.7499999999999992e-06,"systemTime":0,"id":340,"basePriority":81,"name":"AppleSocHot","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067753]},"310":{"continuation":[0,18328644],"userTime":0.36883512499999999,"systemTime":0,"id":310,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":368835,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066793]},"787":{"continuation":[0,18328644],"userTime":0.26692308300000001,"systemTime":0,"id":787,"basePriority":81,"name":"AppleNubSynopsysOTG3Device","user_usec":266923,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075353]},"341":{"continuation":[0,18328644],"userTime":8.2910000000000007e-06,"systemTime":0,"id":341,"basePriority":81,"name":"AppleT8015TempSensor","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067833]},"311":{"continuation":[0,18328644],"userTime":0.63402208299999996,"systemTime":0,"id":311,"basePriority":81,"name":"IOAsynchronousScheduler","user_usec":634022,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066873]},"312":{"continuation":[0,18328644],"userTime":0.0032009159999999998,"systemTime":0,"id":312,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":3200,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066953]},"277":{"continuation":[0,18328644],"userTime":0.0017587499999999999,"systemTime":0,"id":277,"basePriority":81,"name":"AppleT8011USBArbitrator","user_usec":1758,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065113]},"1260":{"id":1260,"schedPriority":47,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"schedFlags":["TH_SFLAG_EAGERPREEMPT"],"user_usec":46817,"basePriority":47,"userTime":0.046817916000000001,"waitEvent":[0,39425664],"continuation":[0,12410180],"systemTime":0,"name":"thread call qos-ui #1"},"373":{"userTime":159.42541883300001,"systemTime":0,"system_usec":0,"id":373,"basePriority":0,"user_usec":159425418,"kernelFrames":[[0,12281284],[0,12281936],[0,19138112]],"schedPriority":0,"name":"idle #4","state":["TH_RUN","TH_IDLE"]},"1126":{"continuation":[0,12410180],"userTime":0.42081225,"systemTime":0,"id":1126,"basePriority":93,"name":"thread call high #5","user_usec":420812,"schedPriority":93,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39422464]},"314":{"continuation":[0,18328644],"userTime":7.9999999999999996e-06,"systemTime":0,"id":314,"basePriority":81,"name":"AppleT8015TempSensor","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067033]},"279":{"continuation":[0,18328644],"userTime":7.7910000000000005e-06,"systemTime":0,"id":279,"basePriority":81,"name":"AppleSamsungSerial","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065193]},"887":{"continuation":[0,31546320],"userTime":0.028798832999999999,"systemTime":0,"id":887,"basePriority":31,"name":"purgatory_cleaner","user_usec":28798,"schedPriority":31,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299594830824897]},"471":{"userTime":0.0047942499999999999,"systemTime":0,"name":"RTBuddyV2","id":471,"basePriority":81,"user_usec":4794,"system_usec":0,"schedPriority":81,"kernelFrames":[[0,12256844],[0,12249632],[0,18328940],[0,19138112]],"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992070473]},"441":{"continuation":[0,18328644],"userTime":0.000106458,"systemTime":0,"id":441,"basePriority":81,"name":"RTBuddyV2","user_usec":106,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069913]},"953":{"continuation":[0,18328644],"userTime":0.00039062500000000002,"systemTime":0,"id":953,"basePriority":81,"name":"AppleSPU","user_usec":390,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077033]},"376":{"continuation":[0,12281864],"userTime":139.47328854099999,"name":"idle #2","id":376,"basePriority":0,"user_usec":139473288,"system_usec":0,"schedPriority":0,"state":["TH_RUN","TH_IDLE"],"systemTime":0},"888":{"userTime":0.32504891600000002,"systemTime":0,"system_usec":0,"id":888,"basePriority":81,"user_usec":325048,"kernelFrames":[[0,12256844],[0,12249632],[0,12168796],[0,16654832],[0,32068552],[0,19138112]],"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299594832858017]},"472":{"continuation":[0,18328644],"userTime":3.8791000000000002e-05,"systemTime":0,"id":472,"basePriority":81,"name":"AppleSEPManager","user_usec":38,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992070553]},"346":{"continuation":[0,18328644],"userTime":0.00065762500000000001,"systemTime":0,"id":346,"basePriority":81,"name":"AppleS5L8940XI2CController","user_usec":657,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067913]},"2587":{"continuation":[0,14323348],"userTime":1.5500000000000001e-05,"systemTime":0,"id":2587,"basePriority":81,"name":"dlil_input_utun2","user_usec":15,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068942593]},"347":{"continuation":[0,18328644],"userTime":7.9580000000000007e-06,"systemTime":0,"id":347,"basePriority":81,"name":"AppleT8015TempSensor","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067993]},"473":{"continuation":[0,18328644],"userTime":1.8624999999999999e-05,"systemTime":0,"id":473,"basePriority":81,"name":"AppleSEPManager","user_usec":18,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992070633]},"378":{"continuation":[0,12281864],"userTime":135.28227662500001,"name":"idle #1","id":378,"basePriority":0,"user_usec":135282276,"system_usec":0,"schedPriority":0,"state":["TH_RUN","TH_IDLE"],"systemTime":0},"474":{"continuation":[0,18328644],"userTime":0.00073025,"systemTime":0,"id":474,"basePriority":81,"name":"AppleSEPManager","user_usec":730,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992070713]},"318":{"continuation":[0,18328644],"userTime":8.1249999999999993e-06,"systemTime":0,"id":318,"basePriority":81,"name":"AppleMCA2Switch_T8015","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067113]},"2588":{"continuation":[0,14354380],"userTime":8.4499999999999994e-05,"systemTime":0,"id":2588,"basePriority":82,"name":"ifnet_start_utun2","user_usec":84,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068940529]},"2779":{"continuation":[0,12410180],"userTime":0.012707708,"systemTime":0,"id":2779,"basePriority":93,"name":"thread call high #5","user_usec":12707,"schedPriority":93,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39422464]},"476":{"continuation":[0,18328644],"userTime":0.0001705,"systemTime":0,"id":476,"basePriority":81,"name":"AppleSEPManager","user_usec":170,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992070793]},"958":{"continuation":[0,18328644],"userTime":0.000294166,"systemTime":0,"id":958,"basePriority":81,"name":"AppleSPU","user_usec":294,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077113]},"4633":{"continuation":[0,12410180],"userTime":0.077277374999999995,"systemTime":0,"id":4633,"basePriority":92,"name":"thread call kernel-high #3","user_usec":77277,"schedPriority":92,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39425024]},"959":{"continuation":[0,18328644],"userTime":0.00039566599999999998,"systemTime":0,"id":959,"basePriority":81,"name":"AppleSPU","user_usec":395,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077193]},"670":{"continuation":[0,18328644],"userTime":0.108649916,"systemTime":0,"id":670,"basePriority":81,"name":"IOGPU Completion","user_usec":108649,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073433]},"2010":{"id":2010,"schedPriority":31,"system_usec":0,"state":["TH_WAIT"],"schedFlags":["TH_SFLAG_EAGERPREEMPT"],"user_usec":21591,"basePriority":31,"userTime":0.021591333000000001,"waitEvent":[0,39423744],"continuation":[0,12410180],"systemTime":0,"name":"thread call user #1"},"610":{"continuation":[0,15153992],"userTime":6.2079999999999997e-06,"systemTime":0,"id":610,"basePriority":81,"name":"CFIL_STATS_REPORT","user_usec":6,"schedPriority":81,"system_usec":0,"state":["TH_WAIT"],"waitEvent":[0,41112220]},"2578":{"continuation":[0,14323348],"userTime":1.1041e-05,"systemTime":0,"id":2578,"basePriority":81,"name":"dlil_input_utun1","user_usec":11,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584010989401]},"515":{"continuation":[0,18328644],"userTime":6.6250000000000001e-06,"systemTime":0,"id":515,"basePriority":81,"name":"AppleMCA2Controller_T8015","user_usec":6,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071833]},"641":{"continuation":[0,18328644],"userTime":4.3329999999999998e-06,"systemTime":0,"id":641,"basePriority":81,"user_usec":4,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072713]},"672":{"continuation":[0,18328644],"userTime":0.032315833000000002,"systemTime":0,"id":672,"basePriority":81,"name":"AGXAcceleratorG10P_B0","user_usec":32315,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073513]},"2579":{"continuation":[0,14354380],"userTime":5.7874999999999997e-05,"systemTime":0,"id":2579,"basePriority":82,"name":"ifnet_start_utun1","user_usec":57,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584010987337]},"547":{"continuation":[0,18328644],"userTime":0.0072491659999999996,"systemTime":0,"id":547,"basePriority":81,"name":"AppleSEPManager","user_usec":7249,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072233]},"673":{"continuation":[0,18328644],"userTime":0.22136620800000001,"systemTime":0,"id":673,"basePriority":81,"name":"AGXAcceleratorG10P_B0","user_usec":221366,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073593]},"101":{"continuation":[0,12965880],"userTime":0.50577937500000003,"systemTime":0,"id":101,"basePriority":91,"name":"VM_pageout_scan","user_usec":505779,"schedPriority":91,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41047532]},"1107":{"continuation":[0,12410180],"userTime":0.028889416000000001,"systemTime":0,"id":1107,"basePriority":93,"name":"thread call high #5","user_usec":28889,"schedPriority":93,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39422464]},"162":{"continuation":[0,18328644],"userTime":8.3329999999999997e-06,"systemTime":0,"id":162,"basePriority":81,"name":"AppleARMBacklight","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064153]},"674":{"continuation":[0,18328644],"userTime":0.00027191599999999998,"systemTime":0,"id":674,"basePriority":81,"name":"AGXAcceleratorG10P_B0","user_usec":271,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073673]},"102":{"continuation":[0,12281864],"userTime":133.33596683299999,"name":"idle #0","id":102,"basePriority":0,"user_usec":133335966,"system_usec":0,"schedPriority":0,"state":["TH_RUN","TH_IDLE"],"systemTime":0},"770":{"id":770,"schedPriority":91,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"schedFlags":["TH_SFLAG_UNKNOWN_0x20000"],"user_usec":9,"basePriority":91,"userTime":9.4579999999999999e-06,"waitEvent":[0,41033792],"continuation":[0,12966008],"systemTime":0,"name":"VM_compressor"},"614":{"continuation":[0,18328644],"userTime":2.9579999999999999e-06,"systemTime":0,"id":614,"basePriority":81,"user_usec":2,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072473]},"2745":{"continuation":[0,17440108],"userTime":0.0074388329999999997,"systemTime":0,"id":2745,"basePriority":81,"name":"skywalk_fsw_reap_awdl0","user_usec":7438,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584041466985]},"163":{"continuation":[0,18328644],"userTime":5.5829999999999997e-06,"systemTime":0,"id":163,"basePriority":81,"name":"AppleARMBacklight","user_usec":5,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064233]},"2160":{"continuation":[0,18328644],"userTime":6.6660000000000002e-06,"systemTime":0,"id":2160,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":6,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992078153]},"103":{"continuation":[0,12261320],"userTime":0.074283583,"systemTime":0,"id":103,"basePriority":95,"name":"sched_maintenance_thread","user_usec":74283,"schedPriority":95,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,12261320]},"771":{"id":771,"schedPriority":91,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"schedFlags":["TH_SFLAG_UNKNOWN_0x20000"],"user_usec":10,"basePriority":91,"userTime":1.0332999999999999e-05,"waitEvent":[0,41033793],"continuation":[0,12966008],"systemTime":0,"name":"VM_compressor"},"164":{"continuation":[0,18328644],"userTime":7.041e-06,"systemTime":0,"id":164,"basePriority":81,"name":"AUC","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064313]},"711":{"continuation":[0,18328644],"userTime":4.9579999999999998e-06,"systemTime":0,"id":711,"basePriority":81,"name":"IOMFBPIODMAManager","user_usec":4,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074233]},"104":{"continuation":[0,12194352],"userTime":0.29554733300000002,"systemTime":0,"id":104,"basePriority":80,"name":"daemon.deferred-deallocation","user_usec":295547,"schedPriority":80,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41389896]},"772":{"continuation":[0,12708864],"userTime":6.9160000000000004e-06,"systemTime":0,"id":772,"basePriority":91,"name":"VM_swapout","user_usec":6,"schedPriority":91,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41007344]},"616":{"continuation":[0,18328644],"userTime":3.5829999999999998e-06,"systemTime":0,"id":616,"basePriority":81,"name":"AppleCS35L26Amp","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072553]},"165":{"continuation":[0,18328644],"userTime":7.2080000000000003e-06,"systemTime":0,"id":165,"basePriority":81,"name":"IOAsynchronousScheduler","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064393]},"291":{"continuation":[0,18328644],"userTime":0.43376391600000003,"systemTime":0,"id":291,"basePriority":81,"name":"AppleT8015PPM","user_usec":433763,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065673]},"2161":{"continuation":[0,18328644],"userTime":6.6250000000000001e-06,"systemTime":0,"id":2161,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":6,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992078233]},"105":{"continuation":[0,12194352],"userTime":1.3916e-05,"systemTime":0,"id":105,"basePriority":93,"name":"daemon.thread-stack","user_usec":13,"schedPriority":93,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41391856]},"773":{"continuation":[0,12711388],"userTime":5.4580000000000001e-06,"systemTime":0,"id":773,"basePriority":91,"name":"VM_swapfile_create","user_usec":5,"schedPriority":91,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41025572]},"2721":{"continuation":[0,14323348],"userTime":1.1e-05,"systemTime":0,"id":2721,"basePriority":81,"name":"dlil_input_awdl0","user_usec":11,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068951545]},"678":{"continuation":[0,18328644],"userTime":3.9999999999999998e-06,"systemTime":0,"id":678,"basePriority":81,"name":"AppleEmbeddedGPSControl","user_usec":4,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073753]},"106":{"id":106,"schedPriority":80,"system_usec":0,"kernelFrames":[[0,12271724]],"state":["TH_WAIT","TH_UNINT"],"user_usec":0,"basePriority":80,"userTime":0,"waitEvent":[0,41391728],"continuation":[0,12194352],"systemTime":0,"name":"daemon.thread-exception"},"870":{"continuation":[0,18328644],"userTime":0.25995241600000002,"systemTime":0,"id":870,"basePriority":81,"name":"AppleH10PearlCam","user_usec":259952,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075673]},"293":{"continuation":[0,18328644],"userTime":8.5830000000000007e-06,"systemTime":0,"id":293,"basePriority":81,"name":"AppleT8015TempSensor","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065753]},"810":{"continuation":[0,14323348],"userTime":2.9579999999999999e-06,"systemTime":0,"id":810,"basePriority":81,"name":"dlil_input_pdp_ip3","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584002773585]},"107":{"continuation":[0,12409196],"userTime":0.00081858300000000001,"systemTime":0,"id":107,"basePriority":94,"name":"thread_call_daemon","user_usec":818,"schedPriority":94,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39427584]},"775":{"continuation":[0,12712104],"userTime":8.1124999999999993e-05,"systemTime":0,"id":775,"basePriority":91,"name":"VM_swapfile_gc","user_usec":81,"schedPriority":91,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41025576]},"263":{"continuation":[0,18328644],"userTime":6.2910000000000004e-06,"systemTime":0,"id":263,"basePriority":81,"name":"AppleT8015PMGR","user_usec":6,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064713]},"2722":{"continuation":[0,14354380],"userTime":0.000121625,"systemTime":0,"id":2722,"basePriority":82,"name":"ifnet_start_awdl0","user_usec":121,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068949481]},"2735":{"continuation":[0,14323348],"userTime":1.9749999999999999e-05,"systemTime":0,"id":2735,"basePriority":81,"name":"dlil_input_llw0","user_usec":19,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068939609]},"715":{"continuation":[0,18328644],"userTime":3.2874999999999999e-05,"systemTime":0,"id":715,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":32,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074313]},"811":{"continuation":[0,14354380],"userTime":2.791e-06,"systemTime":0,"id":811,"basePriority":82,"name":"skywalk_doorbell_pdp_ip3_tx","user_usec":2,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584002771521]},"390":{"continuation":[0,18328644],"userTime":8.833e-06,"systemTime":0,"id":390,"basePriority":81,"name":"AppleT8015DART","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069033]},"108":{"id":108,"schedPriority":81,"system_usec":0,"kernelFrames":[[0,12256844],[0,12249632],[0,12168544],[0,18191688],[0,19138112]],"schedFlags":["TH_SFLAG_UNKNOWN_0x80000"],"user_usec":21498,"state":["TH_WAIT","TH_UNINT"],"basePriority":81,"userTime":0.021498375,"waitEvent":[0,41560672],"systemTime":0,"name":"IOServiceTerminateThread"},"360":{"continuation":[0,18328644],"userTime":1.1583000000000001e-05,"systemTime":0,"id":360,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":11,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992068153]},"4232":{"continuation":[0,12410180],"userTime":0.107876666,"systemTime":0,"id":4232,"basePriority":92,"name":"thread call kernel-high #3","user_usec":107876,"schedPriority":92,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39425024]},"872":{"userTime":4.0829999999999997e-06,"systemTime":0,"name":"AppleH10CamIn_MemoryPressureMonitorThread","id":872,"basePriority":97,"user_usec":4,"system_usec":0,"schedPriority":97,"kernelFrames":[[0,12256844],[0,12249632],[0,12970704],[0,35016952],[0,19138112]],"state":["TH_WAIT"],"waitEvent":[0,41163108]},"2163":{"continuation":[0,18328644],"userTime":7.5830000000000001e-06,"systemTime":0,"id":2163,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992078313]},"300":{"continuation":[0,30919804],"userTime":1.411301291,"systemTime":0,"id":300,"basePriority":95,"name":"AppleCLPC","user_usec":1411301,"schedPriority":95,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583990755753]},"812":{"continuation":[0,14323348],"userTime":3.9580000000000001e-06,"systemTime":0,"id":812,"basePriority":81,"name":"dlil_input_pdp_ip1","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584002776569]},"391":{"continuation":[0,18328644],"userTime":8.9579999999999996e-06,"systemTime":0,"id":391,"basePriority":81,"name":"AppleT8015DART","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069113]},"361":{"userTime":0.000119666,"systemTime":0,"system_usec":0,"id":361,"basePriority":81,"schedFlags":["TH_SFLAG_UNKNOWN_0x80000"],"user_usec":119,"schedPriority":81,"kernelFrames":[[0,12256844],[0,12249632],[0,12168544],[0,18330376],[0,29860912],[0,18341024],[0,29861280],[0,19138112]],"state":["TH_WAIT"],"waitEvent":[1,2315299583995791755]},"2736":{"continuation":[0,14354380],"userTime":1.1165999999999999e-05,"systemTime":0,"id":2736,"basePriority":82,"name":"skywalk_doorbell_llw0_tx","user_usec":11,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068937545]},"873":{"continuation":[0,18328644],"userTime":0.0029892080000000001,"systemTime":0,"id":873,"basePriority":81,"name":"ApplePearlSEPDriver","user_usec":2989,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075753]},"331":{"continuation":[0,18328644],"userTime":0.00063754100000000004,"systemTime":0,"id":331,"basePriority":81,"name":"AppleHapticsSupportCallan","user_usec":637,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067593]},"301":{"continuation":[0,18328644],"userTime":7.4159999999999998e-06,"systemTime":0,"id":301,"basePriority":81,"name":"AppleSamsungSerial","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066073]},"813":{"continuation":[0,14354380],"userTime":9.8749999999999995e-06,"systemTime":0,"id":813,"basePriority":82,"name":"skywalk_doorbell_pdp_ip1_tx","user_usec":9,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584002774505]},"392":{"continuation":[0,18328644],"userTime":7.9160000000000001e-06,"systemTime":0,"id":392,"basePriority":81,"name":"AppleT8015DART","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069193]},"266":{"continuation":[0,18328644],"userTime":6.0000000000000002e-06,"systemTime":0,"id":266,"basePriority":81,"user_usec":6,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064793]},"874":{"userTime":0.014633,"systemTime":0,"system_usec":0,"id":874,"basePriority":81,"user_usec":14633,"kernelFrames":[[0,12256844],[0,12249632],[0,18070536],[0,34460848],[0,19138112]],"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583990716297]},"718":{"continuation":[0,18328644],"userTime":5.4160000000000003e-06,"systemTime":0,"id":718,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":5,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074473]},"297":{"continuation":[0,18328644],"userTime":1.0708e-05,"systemTime":0,"id":297,"basePriority":81,"name":"AppleMCA2Cluster_T8015","user_usec":10,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065833]},"302":{"continuation":[0,18328644],"userTime":0.001478416,"systemTime":0,"id":302,"basePriority":81,"name":"AppleSamsungSPIController","user_usec":1478,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066153]},"814":{"continuation":[0,14323348],"userTime":7.3329999999999999e-06,"systemTime":0,"id":814,"basePriority":81,"name":"dlil_input_pdp_ip2","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584002764633]},"267":{"userTime":0.00027724999999999999,"systemTime":0,"name":"AppleS8000AESAccelerator","id":267,"basePriority":81,"user_usec":277,"system_usec":0,"schedPriority":81,"kernelFrames":[[0,12256844],[0,12249632],[0,18328940],[0,19138112]],"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992064873]},"779":{"continuation":[0,18328644],"userTime":4.1659999999999996e-06,"systemTime":0,"id":779,"basePriority":81,"name":"AppleSMCHighVoltageCharger","user_usec":4,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075273]},"2711":{"continuation":[0,14323348],"userTime":0.094091875000000005,"systemTime":0,"id":2711,"basePriority":81,"name":"dlil_input_en0","user_usec":94091,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068948561]},"3082":{"continuation":[0,17173120],"userTime":4.0040999999999998e-05,"systemTime":0,"id":3082,"basePriority":81,"name":"TRACKER_GC","user_usec":40,"schedPriority":81,"system_usec":0,"state":["TH_WAIT"],"waitEvent":[0,41555464]},"719":{"continuation":[0,18328644],"userTime":3.6660000000000001e-06,"systemTime":0,"id":719,"basePriority":81,"name":"VideoInterfaceMipi","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074553]},"298":{"continuation":[0,18328644],"userTime":8.3329999999999997e-06,"systemTime":0,"id":298,"basePriority":81,"name":"AppleMCA2Cluster_T8015","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065913]},"303":{"continuation":[0,18328644],"userTime":8.8750000000000006e-06,"systemTime":0,"id":303,"basePriority":81,"name":"AppleMCA2Cluster_T8015","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066233]},"815":{"continuation":[0,14354380],"userTime":3.2909999999999999e-06,"systemTime":0,"id":815,"basePriority":82,"name":"skywalk_doorbell_pdp_ip2_tx","user_usec":3,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584002762569]},"394":{"continuation":[0,18328644],"userTime":7.875e-06,"systemTime":0,"id":394,"basePriority":81,"name":"AppleMCA2Controller_T8015","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069273]},"2165":{"continuation":[0,18328644],"userTime":7.4159999999999998e-06,"systemTime":0,"id":2165,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992078393]},"2712":{"continuation":[0,14354380],"userTime":0.017241458000000001,"systemTime":0,"id":2712,"basePriority":82,"name":"skywalk_doorbell_en0_tx","user_usec":17241,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068946497]},"299":{"continuation":[0,18328644],"userTime":0.001116208,"systemTime":0,"id":299,"basePriority":81,"name":"IOPCIConfigurator","user_usec":1116,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065993]},"304":{"continuation":[0,18328644],"userTime":7.875e-06,"systemTime":0,"id":304,"basePriority":81,"name":"AppleSamsungSPIController","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066313]},"816":{"continuation":[0,14323348],"userTime":5.7080000000000002e-06,"systemTime":0,"id":816,"basePriority":81,"name":"dlil_input_pdp_ip4","user_usec":5,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584010992385]},"395":{"continuation":[0,18328644],"userTime":0.001633916,"systemTime":0,"id":395,"basePriority":81,"name":"AppleMCA2Controller_T8015","user_usec":1633,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069353]},"942":{"continuation":[0,18328644],"userTime":0.00050870799999999997,"systemTime":0,"id":942,"basePriority":81,"name":"AppleSPU","user_usec":508,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992076793]},"1413":{"continuation":[0,18328644],"userTime":2.9160000000000001e-06,"systemTime":0,"id":1413,"basePriority":81,"name":"AppleMultitouchHIDService","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077993]},"491":{"continuation":[0,18328644],"userTime":8.6659999999999997e-06,"systemTime":0,"id":491,"basePriority":81,"name":"RTBuddyService","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071193]},"335":{"continuation":[0,18328644],"userTime":8.541e-06,"systemTime":0,"id":335,"basePriority":81,"name":"AppleT8015TempSensor","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992067673]},"305":{"continuation":[0,18328644],"userTime":0.000143125,"systemTime":0,"id":305,"basePriority":81,"name":"AppleJPEGDriver","user_usec":143,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066393]},"817":{"continuation":[0,14354380],"userTime":3.4999999999999999e-06,"systemTime":0,"id":817,"basePriority":82,"name":"skywalk_doorbell_pdp_ip4_tx","user_usec":3,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584010990321]},"396":{"continuation":[0,18328644],"userTime":8.833e-06,"systemTime":0,"id":396,"basePriority":81,"name":"AppleMCA2Controller_T8015","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069433]},"366":{"userTime":160.457572416,"systemTime":0,"system_usec":0,"id":366,"basePriority":0,"user_usec":160457572,"kernelFrames":[[0,12281284],[0,12281936],[0,19138112]],"schedPriority":0,"name":"idle #5","state":["TH_RUN","TH_IDLE"]},"2166":{"continuation":[0,18328644],"userTime":6.9580000000000001e-06,"systemTime":0,"id":2166,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":6,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992078473]},"2713":{"continuation":[0,17440108],"userTime":0.013028415999999999,"systemTime":0,"id":2713,"basePriority":81,"name":"skywalk_fsw_reap_en0","user_usec":13028,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584041465737]},"306":{"continuation":[0,18328644],"userTime":0.0015297080000000001,"systemTime":0,"id":306,"basePriority":81,"name":"AppleS5L8940XI2CController","user_usec":1529,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066473]},"397":{"continuation":[0,18328644],"userTime":8.7499999999999992e-06,"systemTime":0,"id":397,"basePriority":81,"name":"AppleMCA2Controller_T8015","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069513]},"493":{"continuation":[0,18328644],"userTime":9.7207999999999995e-05,"systemTime":0,"id":493,"basePriority":81,"name":"RTBuddyV2","user_usec":97,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071273]},"307":{"continuation":[0,18328644],"userTime":0.00041062500000000002,"systemTime":0,"id":307,"basePriority":81,"name":"AppleS5L8940XI2CController","user_usec":410,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066553]},"1193":{"continuation":[0,18328644],"userTime":2.3329999999999999e-06,"systemTime":0,"id":1193,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077753]},"819":{"continuation":[0,18328644],"userTime":0.00068129099999999999,"systemTime":0,"id":819,"basePriority":81,"name":"AppleSEPManager","user_usec":681,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075593]},"2167":{"continuation":[0,18328644],"userTime":1.0583e-05,"systemTime":0,"id":2167,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":10,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992078553]},"464":{"continuation":[0,18328644],"userTime":0.000109708,"systemTime":0,"id":464,"basePriority":81,"name":"RTBuddyV2","user_usec":109,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992070393]},"590":{"continuation":[0,13900512],"userTime":0.19218054100000001,"systemTime":0,"id":590,"basePriority":81,"user_usec":192180,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41080136]},"308":{"continuation":[0,18328644],"userTime":8.0830000000000004e-06,"systemTime":0,"id":308,"basePriority":81,"name":"AppleS5L8940XI2CController","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066633]},"434":{"userTime":0.0029245410000000001,"systemTime":0,"name":"RTBuddyV2","id":434,"basePriority":81,"user_usec":2924,"system_usec":0,"schedPriority":81,"kernelFrames":[[0,12256844],[0,12249632],[0,18328940],[0,19138112]],"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069753]},"946":{"continuation":[0,18328644],"userTime":0.00021629099999999999,"systemTime":0,"id":946,"basePriority":81,"name":"AppleSPU","user_usec":216,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992076873]},"369":{"continuation":[0,12281864],"userTime":141.46768741599999,"name":"idle #3","id":369,"basePriority":0,"user_usec":141467687,"system_usec":0,"schedPriority":0,"state":["TH_RUN","TH_IDLE"],"systemTime":0},"591":{"continuation":[0,18328644],"userTime":7.4159999999999998e-06,"systemTime":0,"id":591,"basePriority":81,"name":"AppleSEPManager","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072313]},"309":{"continuation":[0,18328644],"userTime":0.27435654100000001,"systemTime":0,"id":309,"basePriority":81,"name":"AppleCLCD","user_usec":274356,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992066713]},"2697":{"continuation":[0,14323348],"userTime":1.1833e-05,"systemTime":0,"id":2697,"basePriority":81,"name":"dlil_input_ap1","user_usec":11,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068945577]},"947":{"continuation":[0,18328644],"userTime":0.00033166599999999999,"systemTime":0,"id":947,"basePriority":81,"name":"AppleSPU","user_usec":331,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992076953]},"2168":{"continuation":[0,18328644],"userTime":8.3329999999999997e-06,"systemTime":0,"id":2168,"basePriority":81,"name":"IOSlowAdaptiveClockingDomain","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992078633]},"917":{"continuation":[0,18328644],"userTime":0.004235,"systemTime":0,"id":917,"basePriority":81,"name":"AppleSPU","user_usec":4235,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075913]},"496":{"continuation":[0,18328644],"userTime":1.1666e-05,"systemTime":0,"id":496,"basePriority":81,"name":"AGXFirmwareKextG10PRTBuddy","user_usec":11,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071353]},"436":{"userTime":0.002113541,"systemTime":0,"name":"RTBuddyV2","id":436,"basePriority":81,"user_usec":2113,"system_usec":0,"schedPriority":81,"kernelFrames":[[0,12256844],[0,12249632],[0,18328940],[0,19138112]],"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992069833]},"948":{"continuation":[0,18328644],"userTime":0.00040491600000000001,"systemTime":0,"id":948,"basePriority":81,"name":"AppleSPU","user_usec":404,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992076713]},"497":{"continuation":[0,18328644],"userTime":0.077750041000000006,"systemTime":0,"id":497,"basePriority":81,"name":"AppleSMC","user_usec":77750,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071433]},"502":{"continuation":[0,18328644],"userTime":0.0072058749999999996,"systemTime":0,"id":502,"basePriority":81,"name":"AppleCBTL1612","user_usec":7205,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071673]},"2698":{"continuation":[0,14354380],"userTime":1.1790999999999999e-05,"systemTime":0,"id":2698,"basePriority":82,"name":"ifnet_start_ap1","user_usec":11,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584068943513]},"498":{"continuation":[0,18328644],"userTime":7.5000000000000002e-06,"systemTime":0,"id":498,"basePriority":81,"name":"AppleSEPARTService","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071513]},"594":{"continuation":[0,16914080],"userTime":0.00060062500000000003,"systemTime":0,"id":594,"basePriority":81,"user_usec":600,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41553888]},"534":{"continuation":[0,18328644],"userTime":0.0011008330000000001,"systemTime":0,"id":534,"basePriority":81,"name":"AppleMCA2Controller_T8015","user_usec":1100,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072073]},"660":{"continuation":[0,18328644],"userTime":3.416e-06,"systemTime":0,"id":660,"basePriority":81,"name":"AppleSMCPMU","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073033]},"499":{"continuation":[0,18328644],"userTime":2.9040999999999999e-05,"systemTime":0,"id":499,"basePriority":81,"name":"RTBuddyService","user_usec":29,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071593]},"595":{"continuation":[0,16373008],"userTime":4.4580000000000003e-06,"systemTime":0,"id":595,"basePriority":81,"user_usec":4,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39502824]},"600":{"continuation":[0,14326092],"userTime":0.12835458299999999,"systemTime":0,"id":600,"basePriority":81,"user_usec":128354,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41515576]},"661":{"continuation":[0,18328644],"userTime":4.1250000000000003e-06,"systemTime":0,"id":661,"basePriority":81,"name":"AppleSMCChargerPS","user_usec":4,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073113]},"596":{"continuation":[0,16373008],"userTime":2.5830000000000001e-06,"systemTime":0,"id":596,"basePriority":81,"user_usec":2,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39502824]},"601":{"continuation":[0,14308944],"userTime":1.5790999999999998e-05,"systemTime":0,"id":601,"basePriority":81,"user_usec":15,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41515976]},"662":{"continuation":[0,18328644],"userTime":3.0000000000000001e-06,"systemTime":0,"id":662,"basePriority":81,"name":"AVE_Drv","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073193]},"597":{"continuation":[0,16655552],"userTime":0.00054541599999999996,"systemTime":0,"id":597,"basePriority":81,"user_usec":545,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41522488]},"602":{"continuation":[0,18328644],"userTime":0.040348624999999999,"systemTime":0,"id":602,"basePriority":81,"name":"AppleHIDTransportDeviceSPI","user_usec":40348,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072393]},"693":{"continuation":[0,18328644],"userTime":3.5290999999999998e-05,"systemTime":0,"id":693,"basePriority":81,"name":"RTBuddyV2","user_usec":35,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073913]},"151":{"continuation":[0,18328644],"userTime":8.6166000000000001e-05,"systemTime":0,"id":151,"basePriority":81,"name":"AppleBasebandD101","user_usec":86,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063833]},"507":{"continuation":[0,18328644],"userTime":0.00030729100000000001,"systemTime":0,"id":507,"basePriority":81,"name":"ApplePMP","user_usec":307,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992071753]},"598":{"continuation":[0,16655552],"userTime":4.6659999999999999e-06,"systemTime":0,"id":598,"basePriority":81,"user_usec":4,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,14908852]},"603":{"continuation":[0,16655552],"userTime":1.8082999999999999e-05,"systemTime":0,"id":603,"basePriority":81,"user_usec":18,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41558824]},"152":{"continuation":[0,18328644],"userTime":1.0541e-05,"systemTime":0,"id":152,"basePriority":81,"name":"AppleM68Buttons","user_usec":10,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063913]},"538":{"continuation":[0,18328644],"userTime":8.1659999999999994e-06,"systemTime":0,"id":538,"basePriority":81,"name":"AppleMCA2Controller_T8015","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992072153]},"760":{"continuation":[0,18328644],"userTime":2.5830000000000001e-06,"systemTime":0,"id":760,"basePriority":81,"name":"AppleImage4","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075113]},"599":{"continuation":[0,16655552],"userTime":2.875e-06,"systemTime":0,"id":599,"basePriority":81,"user_usec":2,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,39451648]},"604":{"continuation":[0,16655552],"userTime":3.7079999999999999e-06,"systemTime":0,"id":604,"basePriority":81,"user_usec":3,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41558840]},"1880":{"continuation":[0,14323348],"userTime":8.8750000000000006e-06,"systemTime":0,"id":1880,"basePriority":81,"name":"dlil_input_en1","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584010995369]},"153":{"continuation":[0,12906752],"userTime":7.2125000000000005e-05,"systemTime":0,"id":153,"basePriority":95,"name":"VM_io_reprioritize_thread","user_usec":72,"schedPriority":95,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41033600]},"700":{"continuation":[0,18328644],"userTime":0.755951916,"systemTime":0,"id":700,"basePriority":81,"name":"AppleBCMWLANBusInterfacePCIe","user_usec":755951,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074073]},"605":{"continuation":[0,16719604],"userTime":0.00025595799999999998,"systemTime":0,"id":605,"basePriority":81,"name":"VM_freezer","user_usec":255,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41162784]},"280":{"continuation":[0,18328644],"userTime":0.001763,"systemTime":0,"id":280,"basePriority":81,"name":"AppleGen0SPMIController","user_usec":1763,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065273]},"1217":{"continuation":[0,18328644],"userTime":0.00042341600000000003,"systemTime":0,"id":1217,"basePriority":81,"name":"AppleICA60","user_usec":423,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992077913]},"762":{"continuation":[0,18328644],"userTime":4.25e-06,"systemTime":0,"id":762,"basePriority":81,"name":"AppleMobileApNonce","user_usec":4,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075193]},"606":{"continuation":[0,16684812],"userTime":7.6660000000000008e-06,"systemTime":0,"id":606,"basePriority":95,"name":"VM_memorystatus_1","user_usec":7,"schedPriority":95,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299579920588901]},"1881":{"continuation":[0,14354380],"userTime":6.9160000000000004e-06,"systemTime":0,"id":1881,"basePriority":82,"name":"ifnet_start_en1","user_usec":6,"schedPriority":82,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299584010993305]},"155":{"continuation":[0,16655552],"userTime":6.7909999999999999e-06,"systemTime":0,"id":155,"basePriority":81,"user_usec":6,"system_usec":0,"schedPriority":81,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41507456]},"281":{"continuation":[0,18328644],"userTime":8.4579999999999993e-06,"systemTime":0,"id":281,"basePriority":81,"name":"AppleDieTempController","user_usec":8,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065353]},"702":{"continuation":[0,18328644],"userTime":3.7079999999999999e-06,"systemTime":0,"id":702,"basePriority":81,"name":"BTDebug","user_usec":3,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992074153]},"607":{"continuation":[0,16684812],"userTime":6.6660000000000002e-06,"systemTime":0,"id":607,"basePriority":95,"name":"VM_memorystatus_2","user_usec":6,"schedPriority":95,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299579920588925]},"698":{"continuation":[0,18328644],"userTime":0.0029009999999999999,"systemTime":0,"id":698,"basePriority":81,"name":"InterruptEventSourceBridge","user_usec":2901,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073993]},"668":{"continuation":[0,18328644],"userTime":2.875e-06,"systemTime":0,"id":668,"basePriority":81,"name":"IOGPU Default WorkLoop","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073273]},"794":{"userTime":9.2080000000000006e-06,"systemTime":0,"system_usec":0,"id":794,"basePriority":81,"user_usec":9,"kernelFrames":[[0,12256844],[0,12249632],[0,21109244],[0,21085584],[0,18341024],[0,21085160],[0,21331192],[0,19138112]],"schedPriority":81,"state":["TH_WAIT"],"waitEvent":[1,2315299583992997193]},"608":{"continuation":[0,16684812],"userTime":4.2910000000000001e-06,"systemTime":0,"id":608,"basePriority":95,"name":"VM_memorystatus_3","user_usec":4,"schedPriority":95,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299579920588949]},"157":{"continuation":[0,18328644],"userTime":9.6660000000000003e-06,"systemTime":0,"id":157,"basePriority":81,"name":"AppleARMSlowAdaptiveClockingManager","user_usec":9,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992063993]},"669":{"continuation":[0,18328644],"userTime":2.875e-06,"systemTime":0,"id":669,"basePriority":81,"name":"IOGPU Submission","user_usec":2,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992073353]},"765":{"continuation":[0,12972608],"userTime":0.0040262910000000004,"systemTime":0,"id":765,"basePriority":91,"name":"VM_pageout_external_iothread","user_usec":4026,"schedPriority":91,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,41033856]},"609":{"continuation":[0,15156948],"userTime":9.9159999999999996e-06,"systemTime":0,"id":609,"basePriority":81,"name":"CFIL_UPD_GC","user_usec":9,"schedPriority":81,"system_usec":0,"state":["TH_WAIT"],"waitEvent":[0,41112216]},"891":{"continuation":[0,31546320],"userTime":0.000213,"systemTime":0,"id":891,"basePriority":31,"name":"purgatory_cleaner","user_usec":213,"schedPriority":31,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299594830792129]},"861":{"continuation":[0,31546320],"userTime":0.00024875,"systemTime":0,"id":861,"basePriority":31,"name":"purgatory_cleaner","user_usec":248,"schedPriority":31,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299594830816705]},"284":{"continuation":[0,18328644],"userTime":1.0000000000000001e-05,"systemTime":0,"id":284,"basePriority":81,"name":"AppleSynopsysMIPIDSIController","user_usec":10,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992065433]},"801":{"continuation":[0,18328644],"userTime":8.1166000000000002e-05,"systemTime":0,"id":801,"basePriority":81,"name":"AppleBasebandPCIPDPSkywalkInterface","user_usec":81,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992075513]},"380":{"continuation":[0,18328644],"userTime":1.0958000000000001e-05,"systemTime":0,"id":380,"basePriority":81,"name":"AppleD5500","user_usec":10,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,2315299583992068233]},"766":{"continuation":[0,12965280],"userTime":0.0056714579999999999,"systemTime":0,"id":766,"basePriority":31,"name":"VM_pageout_garbage_collect","user_usec":5671,"schedPriority":31,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[0,12965280]},"1883":{"continuation":[0,14323348],"userTime":7.3329999999999999e-06,"systemTime":0,"id":1883,"basePriority":81,"name":"dlil_input_en2","user_usec":7,"schedPriority":81,"system_usec":0,"state":["TH_WAIT","TH_UNINT"],"waitEvent":[1,23152995
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
4 件のコメント
i have the same issue but my phone does’nt restart in 3 min my phone is restarting random time some times it restart after one hour some times it restart after 20 min
what should i do
さんによる
@MIR GamingYT Best way to get answers is to start a new question. Check for panic log entries and add them to your post if any are present. The first page or so is usually sufficient.
iPhone Kernel Panics
さんによる
Dear,
I had the same isseu with my ipad 6 and it ended up in a bootloop then only recovery. not able to restore it.
I did something you could try as last resort if the device is compleet dead like mine.
I did it in the past with gpu,s and i put the logicboard in the over for 10 min at 180 degrees coverd the ports and charging port with thermal pads and it works fine now .
さんによる
I have the same problem but I notice that when my phone is running something in background it won’t restart, AO I turned on background sound in my control Centre and put the volume to zero and it always stay on as it should be but anytime I forget to turn it on my I’ll always meet my phone switched itself off
さんによる
コメントを追加
7件の回答
ベストアンサー
“no successful checkins from thermalmonitord since load” It is either the charge port or in rare cases could be the housing causing it. You need to source a charge port from a reputable supplier. If you purchase elsewhere there is a good chance the sensors on it are faulty or non-existent.
If you are repairing phones you should have a known good housing and screen for each model. This way you can eliminate a parts issue in the least amount of time.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
Thanks. I do not have a spare housing but I'm curious, how would the housing cause the assembly to fail? 99% of my parts are purchased from Mobilesentrix.
さんによる
@larry767 From the 8 series up I have noticed if the housing replacement is not genuine it seems to create problems sometimes in the buttons or the wireless charging. I always have a known good working housing so I can completely rule out parts. Alternatively you could remove the board and just have the screen, battery and dock connected. I would also try another charge port from a different supplier as they can get faulty batchers in.
さんによる
Just as a confirmation of this. This panic specifically refers to missing mic1. That’s on the charge port assembly.
さんによる
コメントを追加
I had the same issue . I bought My
3 months ago “12 pro max 512” One day it felt a little slow so I decided to reset the network setting however It never booted back and got stuck on apple logo for more than 5 hours.. then i decided to not wait any longer and restore it using iTunes . unfortunately after restoring it gets stuck again on the Apple logo. at this point I was pretty !#^&@@ so I factory reset it and had to suffer a significant data loss . What a f cking garbage ! Highly overrated pice of junk . Never again
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I experienced the same issue on iPhone XS Max, and iPhone X. The only solution that has helped me was to change the entire housing. Get a complete casing from a local phone engineer or used phone spare parts reseller.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi. I had this bug pop up in my log, on iPhone XR after troubleshooting an issue on my paired Apple Watch 6. My Apple Watch 6 is on, and display is blank, but is working perfectly in voice over mode. Basically, it’s working in every way, I can erase/restore/pair/unpair an Apple Watch 6 (does not meet current repair service program requirements FYI) completely blind! And the only trouble I’ve had on any devices linked to my iCloud, is on my watch. Does anyone know if that error could be related? Had Apple account lock down on me too, right after troubleshooting watch. Was forced to update my password to unlock account, right after I finished troubleshooting watch… and saw this in my log. Time stamp coincides with all strange behavior, too. Something weird is going on.
さんによる
コメントを追加
From iPhone 8 upwards you MUST use genuine charging flex because they have temperature sensors which are not present on generic otherwise they will reboot every 3 minutes, if the original flex is not damaged you can swop the port only.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did you try booting the phone with prox disconnected? I’ve seen prox sensor cause boot loop
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes and it made no difference. It's not a boot loop. It boots but doesn't detect "thermalmonitord" within 180 seconds and reboots.
さんによる
コメントを追加
Sorry for late reply but as others said about back housing…I agree with them….you can then try to unscrew all screw that connect logic board and back house you can disconnect back camera too.then turn on the phone and check.
You can ask why?
The reason is screw can short to ground and cause some issues like phone turned on but no display,phone turned on but dark camera and so
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
OK, thanks for that explanation. I ended up killing the phone taking it apart and reassembling it so now it won't turn on (draws 0 amps). I sent it away to a friend who can diagnose and repair shorts and damaged components (microsolder repair) and he's been helping me troubleshoot this for several weeks. Hopefully he has spare parts and such that can get to the bottom of this issue. I'll report back when I know more.
さんによる
Okay if it drain 0A he must check PP_BATT_VDD and PP_VDD_MAIN(350-470 diode value) if are both okay then there must be loose connection between logic board and signal board. So my advise separate the phone and test using iSocket if no hope let me know for more assistance
さんによる
panicString” : “panic(cpu 1 caller 0xfffffff01c6e3fac): SMC PANIC - ASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERTION FAILED: target\/d27\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit:
さんによる
コメントを追加
Had the same issue
i solved it by removing the small flexcables that came on the housing
just swap the old one over
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Larry Jorgenson さん、ありがとうございました!
統計データ:
過去 24時間: 51
過去 7 日: 324
過去 30 日: 1,459
今までの合計 50,652
