メインコンテンツにスキップ
Guides and repair information for KitchenAid mixers.
133回答 すべてを表示
Stuck on and in one speed?
Hello everyone ,
A while ago, I was making croissants in my Kitchen-aid mixer. I think it was not able to handle the dough since it heated up. Ever since, the mixer won’t turn off and is stuck on low speed. The lever moves but the speed stays the same. I have to unplug it to get it to turn off.
I think this is a pretty easy fix but haven’t been able to find the exact problem.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
the problem would be in the centrifugal speed governor at the back of the unit.
It is not intuitively obvious the way it functions so it maybe problematic to fix it without someone who understands it being able to see it. I have fixed these before but I would need to have hands on to do it again.
If you can remove the cover and observe it operating (or not) and are mechanically minded, you may be able to discern what is wrong. Be aware that device is handling the full AC voltage to the motor - LOOK, DON’T TOUCH when it is plugged in.
Newer models may have an electronic device instead of the mechanical centrifugal governor.
Basically, the lever sets the position of the contacts on the governor. As the unit speeds up it rotates the governor weights which move the contacts apart. When they reach the limit, the machine shuts off, as it slows down the contacts are made and it speeds up. It is called a “bang-bang” system. It is either on or off.
If it is always on at low speed, I would guess that the speed lever is not moving the governor mechanism, but the governor is working - otherwise it would be running at high speed, always on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kaley Eidson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 67
今までの合計 1,930
