Water Damage
My Sony Ericsson xperia x10 fell into water and just went black. It still charges but now i need to see if it works.Should i send it to Sony Ericsson or how can i get it fixed?
Anna.Zimbabwe
この質問は役に立ちましたか?
Anna.Zimbabwe
この質問は役に立ちましたか?
Anna I would suggest that you first clean your device. Use this as your guide. After that, re-evaluate your phone. you can try a restore by downloading PC SUIT from here
install it, start the Software
Press Tools
Press Phone repair
Press Continue
Wait for PC Suit to download the file
Follow the prompts and select Model X10
Connect your phone while holding the back button and plug the USB cord in. Let the drivers install wan wait while it completes.
Again this may or may not work. I am really more leaning toward you needing a new LCD due to the water damage. But follow the steps anyway. You can download the compete service manual from here. Hope this helps and gets you started in the right direction. Good Luck
このアンサーは役に立ちましたか?
Sorry, I posted at the same time
Wow great minds think alike ;-)
Hey dear, the same thing happened to my experia arc. Gosh its brande new.. it fell into the toilet lol.
ok well, bo panic. all you should do is dry it with a vacuum. Or place in the sunshine for few hrs without touching it or turning it on constently please. turning on a cell when its still dry frys the cell. You can also place it infront of the fan for few hrs. When you see its completely dry only than put in the battery and sim and turn it on. Remember they drying process should be done with having the battery and sim out of it in first.
It will really help. If not, than you have to seperate all the partd and dry eah part individually. and fix it and turn it on..
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 5,384
2 件のコメント
Anna is it an X10 or a x10 Mini E10?
oldturkey03 さんによる 共有
toilet no good. dirty phone. buy new telephone.
rafael rodrigues さんによる 共有
