メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony WH-1000XM2 ワイヤレスノイズキャンセリングオーバーイヤーヘッドホンの修理および分解情報。
Left speaker not working
Hi,
My left speaker stopped working. Touch is still working on the left side, right speaker works fine.
Can anyone advise which cables I should check/replace and Mark them in the attached image?
画像
I have opened up the headphones.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Does the left speaker not work on wired mode(3.5mm cable), wireless mode(Bluetooth), or both?
さんによる 共有
It doesn't work wired and unwired
さんによる 共有
Hello,
Had the same issue with left speaker no longer working (after crackling for a few weeks),
The continuity of the wires was OK, however there is no continuity in the speaker itself once disconnected from the electronic board.
Do you know where to find a replacement speaker for hw-1000m2 ?
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
This sounds like a connection problem or a bad speaker. Can you take the circuit board and any protecting plastic off the left speaker cup?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I should be able to do that. What should I look out for?
さんによる 共有
@mrvolcan Make sure there are 2 wires connected from the speaker to the board. Make sure both of the wires have continuity from one side to the other. If both of those pass, comment both checks passed.
さんによる 共有
I have the exact same problem. This evening the left speaker if my sony wh-1000xm2 decided to stop working. I don't know what to do.
さんによる 共有
コメントを追加
I assume it is an connection problem between the pcbs on both sides. I have the same problem now with my headphones. I seems like there is no signal for the left driver. Anybody figured out the problem?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Moritz さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 50
今までの合計 2,071
