メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
250GB HDDと内蔵Wi-Fiを搭載した、クラシックなXbox 360の薄型モデルです。修理には複雑なこじ開け作業と専用のツールが必要です。
Solid red light on console
Yesterday when we turn it on, it would turn off until a bit warm but today when we turned the Xbox on it is a solid red light. We removed the hard drive and inserted a memory card but that doesn't work, we took the Xbox apart and did a full clean and it still doing the same, removed the cables and put everything back but that is also not working. I have been living on google the whole day. Anyone got some advice that I have not tried yet?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
i have this to but it always is warm and works perfectly and i was going to play with my brother and the xbox it was red so i restarted it and nothing happened it was the same thing RED I DID THE SAME THING NOTHING JUST RED
pls help me with this
さんによる 共有
Today I was going to play with my brother on the Xbox 360 and it was red so I restarted it and it was red just red please help me with this I did the same thing as the top comment
さんによる 共有
コメントを追加
5件の回答
ベストアンサー
We know you get a red light on the console itself, what color is the light on the power brick? If it is red it is likely defective. If the power brick checks out okay, see if you can get a secondary error code out of the console. You should be able to do this by holding the controller sync button and then hitting the eject button. You can do this 4 times to get 4 numbers. One light illuminated is a 1, two lights is 2, 3 lights is 3, and 4 lights is 0.
このアンサーは役に立ちましたか?
スコア 4
11 件のコメント:
Hi Ben, I never knew the model 1439 gave error codes but the brick is yellow and when I tried the sync button with eject button, the control had 4 green lights flash and still red on the console but I don't know if I did it right ?‍♀️?‍♀️
さんによる 共有
@nikki24 Keep hitting that eject and sync combo until it goes back to just the red light. Should be 4 presses to get to the last light combination and the 5th should return to just the red dot. Each press will reveal a light combination. Let me know how many lights are illuminated after each press, should be between 1 and 4 each time.
さんによる 共有
0003 is what I got. I have zero clue what it means!
さんによる 共有
@armorben please tell me it is something small that can be easily repaired and won't cost more than buying a ps4 or a new Xbox!
さんによる 共有
@nikki24 Unfortunately that error is not good. 0003 (also known as E03) indicates that the APU in the console is not receiving power. It could be a bad mosfet or a cold solder joint under the APU, this was more common on the original models but still happened on the earlier S model consoles. Either way replacing it would likely be cheaper than fixing it. Sorry to give you the bad news.
さんによる 共有
6件以上のコメントを表示
コメントを追加
The code I got was 0101
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Red light on power button
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yo, i didnt check on mine but i think mine is just the thermal paste or the cable of the optic drive that is not connected properly.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
GUYS THE RED MEANS a hardware failure often Caused by overheating power supply issues Or internal Competent Failure
さんによる 共有
コメントを追加
found this wiki article that explains the error codes
https://consolemods.org/wiki/Xbox_360:Er...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nakita Brandford さん、ありがとうございました!
統計データ:
過去 24時間: 19
過去 7 日: 141
過去 30 日: 703
今までの合計 29,960
