メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Tab A 10.1は、機能によってモデルが異なります。2016年5月発売の標準モデル:SM-T580 (WiFi)、SM-T585 (3G, 4G/LTEおよびWiFi)、または2016年9月発売のS-Penモデル:SM-P580 (WiFi)、SM-P585 (3G, 4G/LTEおよびWiFi)があります。これはSamsung Electronicsが製造する、同社の新しいハイエンド「A」シリーズの10.1インチタブレットです。
Forgot lock code won't power off can't perform reset?
I forgot my screen lock code and can't power off to perform reset what's next option?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
8件の回答
最も参考になった回答
Press and hold power button and both volume buttons to force reboot your device. After force reboot immediately press and hold hard reset combination buttons. it will take few attempts and then you will reach to recovery mode to wipe/factory reset your Samsung device.
If you have the Samsung device then after factory reset it will FRP Google account locked to unlock it follow this guidelines.
How to Bypass Samsung FRP Lock
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
I tried all that but keeps asking for passcode
さんによる 共有
I tried it all too and it still wants a password.
さんによる 共有
Finally found something that worked, was able to use last known passcode to finalize reboot.
さんによる 共有
I tried that it still asks for a password
さんによる 共有
コメントを追加
IT DOES NOT WORK I TRIED EVERYTHING
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Press and hold power button and both volume buttons to force reboot your device. After force reboot immediately press and hold hard reset combination buttons. it will take few attempts and then you will reach to recovery mode to wipe/factory reset your Samsung device. did not work
さんによる 共有
I have tried everything as well and nothing works. It's like it goes to sleep the screen Is dark but device is not off. Then I hit combo of buttons recommend to turn off and you think it has but it just restarts and your back to the password screen. My mom switched to apple and does not know any of the password for this or anything. She told me just do a factory reset. I can't even turn the device off to attempt to bring up the menu to do the factory reset.
さんによる 共有
What are the “hard reset combination buttons”?
さんによる 共有
コメントを追加
What buttons are press and hold hard reset combination.?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Well, if it is a 4 digit pass code you could start at 0000 and run to 9999. It may take a while.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I finally found a solution. Although google claims it will remove this device from your account if it is not used in 28 days, I took no chances. My solution involved a #3 sledge hammer. I then submerged the remaining pieces in several ounces of water for several hours.
Be very careful when you do this, though. The battery can get quite hot. I have a small blister on my left little finger.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have been considering this solution as it seems to be the only one with an actual result that isn't the same lock screen
さんによる 共有
コメントを追加
How do I power off my Android tablet it won't do anything
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Locked out of EVERYTHING don’t no passcode
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Help can’t get on anything without a passcode that I don’t remember! Not power off nothing!
さんによる 共有
Samsung Galaxy
さんによる 共有
コメントを追加
Try this pc on side plug In USB..then go to Olin software...Set the Samsung tablet to download two buttons volumup and down together than plug in your USB to get Samsung green screen then tap volume up to down load screen then down load you Sm200 firmware thru Olin...Your will wait till it finish reboot go to reset factory settings...Sorry it is the only way back to normal working conditions....good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kristina quinn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 49
今までの合計 16,266
