メインコンテンツにスキップ
IBM社が販売し、2005年にLenovo社が買収したビジネス向けノートパソコンのシリーズ。旧モデル(Pre-XX50)にはWiFiホワイトリストがあるため、ワイヤレスカードの交換は、オンラインで一括してジェネリックカードを購入するほど簡単ではありません。
713回答 すべてを表示
Thinkpad 2 Lenovo Red blinking light and my computer will not start
I have a Red blinking light on my Laptop and my computer will not start. How long should I keep it charging. The red blinking light has continued for a couple of days and won’t start? It's a Thinkpad 2 Lenovo What does that mean? Should I continue charging. I want to also assure that I'm not wiped out on my computer. How may I assess the programs if repair is needed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
wait to light turn white then turn on the laptop
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If the LT is plugged in and charging, it should start regardless of the charge level of the battery.
Unplug and remove battery. Press and hold power button for 5 sec. Plug in charger and see if it turns on. If so, turn off, insert battery and try again. If it again does not go on, It is possible the battery is pulling too much current. Replace battery.
If it does the same thing with only the charger, then there is an internal problem and needs serious help.
Note that this kind of problem can be economically prohibitive to repair.
You can access your data by removing the memory device (HDD or SSD), installing in an external enclosure and plugging that into another computer. Note, You may need to get more advice on accessing your data especially if you have encrypted it. It will likely object to your access in another computer and you will have to take ownership of the files in the new computer.
You don’t by change (or smart planning) have your data backed up anyplace, do you?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
martha williams さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 44
過去 30 日: 244
今までの合計 19,694
