Is the CPU replaceable?
Thinking to change it from i7-6700T to i7-7700T
Hi,
It might be as the chipset on the motherboard is an Intel H170 which supports an i7 7700T
The big problem is whether the original CPU is hard mounted on the motherboard or not and can be removed.
Here’s the ifixit Asus Zen AiO Pro Z240ICのマザーボードの交換 guide. Unfortunately the image in Step.14 doesn’t show whether it is or not as the heatsink is still in position
Hi,
Looks like I didn’t scroll down far enough ;-) and also it looks like you’re right when looking at a close up image of the CPU
(click on image to enlarge for better viewing)
Just wondering if it would be worth it though looking at this
The real world speed test of 74.2% vs 72.4% is only a 1.8% difference, so will it be even noticeable?
このアンサーは役に立ちましたか?
I've found it from Asus Zen AiO Pro Z240IC Heat Sink Replacement, under Step 16.
It seems like the CPU is replaceable.
過去 24時間: 2
過去 7 日: 5
過去 30 日: 35
今までの合計 1,276
