メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
バッテリーのアップグレードやディスプレイの修理を含むPSP Goの完全修理マニュアルです。
PSP Go - No Power, No Charging
Day before yesterday every time I plug in the charger orange light turns on for little while then it turn it self off, now since yesterday my PSP Go doesn't charge, NO orange light and I can't turn it on.
Any word of advice how can I determine what's causing this problem (USB cable, AC adapter, or PSP itself)?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
4件の回答
ベストアンサー
hold square triangle start select and home and turn it on good luck:)
このアンサーは役に立ちましたか?
スコア 7
4 件のコメント:
great thanks really helped ..
さんによる
no it didn`t..
さんによる
I cant believe this worked, after around 9 years of not being able to use my psp go, this helped. PSP GO is like new and i can continue my gaming
さんによる
this trick worked on my psp go that only charged with compatible cables. i tried 2 different original cables and no luck on charging or connecting to pc on usb mode. after the trick works wonders
さんによる
コメントを追加
Wolfin2010, check your AC adapter with a multimeter/voltmeter just to make sure it works. Also check your cable and make sure it is not frayed and in good working order. Check the plug on your PSP and make sure it does not have any corrosion or other damage. If all that checks out, I would try a new battery. PSP Goのバッテリーの交換 after that it is time to reevaluate. If you are really handy, check on here for the fuse location of your go and check your fuses to make sure they are all okay. Hope this will at least get you started. Good Luck
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi I already replaced my battery but am having issues again. Any ideas?
さんによる
コメントを追加
Having same problem with my PSP1001 going to try resetting first if that don't work then I will test the charging pin to see if its not making good contact.9 out of 10 times its one of these…..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
2019, PSP go hasnt worked since I was a kid (about 10 years ago when I took a trip overseas) and tried this AND IT WORKED. I cant even believe it I'm so excited. Give me your EXACT address so I can come kiss you my good sir
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wolfin2010 さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 28
過去 30 日: 142
今までの合計 36,412
