メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年6月発売 / Turbo Boost対応Core i7プロセッサ / 最大1 GB GDDR5ビデオメモリ
Mid 2012 MBP Hardware Upgrades
I want to upgrade my laptop’s current HD & RAM, possibly removing the Optical Drive as well since it doesn’t work anymore.
Any Suggestions ?
It’s not for super critical work such as Audio or Video Editing, I just need it to be faster, or as fast as it can get.
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
To start with I would bump the RAM to 16GB which is the systems limit MacBook Pro 15インチ Unibody Mid 2012 RAMの交換
As for as drives I would go with a 1TB so you have plenty of space. I would go with a SSD Vs HD as its just more rugged and uses less power MacBook Pro 15インチ Unibody Mid 2012 ハードドライブの交換.
The one issue you do face is the HD SATA cable will likely need to be replaced if you still have the original HDD in the system as the original cable was not able to run at the higher SATA III (6.0 Gb/s) data rates the SSD will push without encountering issues MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable I would also apply a strip of electricians tape on the upper case where the cable crosses over and explained here Your Hard Drive Cable Is A Ticking Time Bomb
The last issue is making sure you don’t damage the cable installing it. A common failure I see is people crease the cable which damages the thin foil wires with in the cable. I use an old BIC pen ink straw as a bending brake to form the bends so I don’t exceed the radius of the straw.
I would leave the optical drive alone as it needed for structure and with one large drive you should not need a second.
Replace a damaged cable connecting the hard drive to the logic board in your laptop.の画像
製品
$19.99
MacBook Pro 15" Unibody Mid 2012 ハードドライブの画像
ガイド
難易度:
中レベル
20 - 30 minutes
MacBook Pro 15" Unibody Mid 2012 RAMの画像
ガイド
難易度:
簡単
10 - 45 minutes
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I think the original HD was already replaced because the HD in it now is a 1TB, but good looking out with regards to the HD Cable installation.
さんによる
An SSD will give you a perceived 100% speed increase.
さんによる
That trick with the old bic ink straw to limit the radius of a bend for the ribbon cable - I'll be keeping that in mind.
さんによる
コメントを追加
回答を追加する
immanueltnt さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 7
過去 30 日: 27
今までの合計 256
