メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年2月に発売された、Samsungの第10世代Galaxyフラッグシップスマートフォンの大型モデル。Android 9.0 (Pie) 搭載。
How to refurbish screen
So I dropped my phone and my screen was working but it had really bad crack, it did not have any dead pixels but after a day the screen went full black, my question is can i just replace polarizer and should then the phone work or is it damaged and i need to buy a new lcd now? How to check that?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Well since you now have a black screen, the answer should be pretty obvious. You need to buy a new screen. The S10 plus uses OLED panels and whenever you break the screen whether it’s just the glass or you get a black screen, the only way to repair it is to replace the screen. OLED is very thin and fragile which just makes it difficult to repair.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Hi @dominik7111 ,
To add to the answer here's the ifixit Samsung Galaxy S10+ スクリーンの交換 guide that may help.
さんによる 共有
So i can not just replace one part of the screen? Because i was wondering how it happend that it works one day and then goes complitly black and it havent got any dead pixels
さんによる 共有
yes you can't replace only certain parts of OLED screens and as a repair shop owner and technician, I speak from experience. The reason why it stopped working was because the OLED panel is fragile. When you cracked the glass that protects it, tiny shards of glass damaged it. Ever scenario is different. In some cases, people damage the OLED while the glass is completely unharmed.
さんによる 共有
What if the screen itself the pixels are all there and working fine but the top layer is cracked can the oled be saved
さんによる 共有
コメントを追加
回答を追加する
Dominik K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 37
今までの合計 798
