メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
293回答 すべてを表示
Ask to upgrade SSD for iMac 2017 27 inch
I want to upgrade SSD for iMac 5k 2017 27 inch, i want to upgrade samsung 970 evo SSD, is it compatible?
I asked a 1TB Samsung 970 EVO Plus PCIe NVMe SSD but they said it couldn't be plugged in.
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Here's a good write up on Apples custom SSD's The Ultimate Guide to Apple’s Proprietary SSDs
さんによる
コメントを追加
2件の回答
ベストアンサー
Here’s the two guides we have on drive upgrades:
Consider the amount of work as well as what your current system has already present. A Fusion drive’d system will have both drives present.
iMac 27" 2017 ハードドライブの画像
ガイド
iMac 27インチ 2017 ハードドライブの交換
難易度:
中レベル
1 - 2 hours
iMac 27" 2017 Blade SSDの画像
ガイド
iMac 27インチ 2017 Blade SSDの交換
難易度:
中レベル
1 - 3 hours
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Can i replace it with samsung PCIe? Because if the Sata drive speed will be worse. Thanks
さんによる
There is two aspects here: Yes you can do it using an adapter. But! given how far you need to dig in to get to it and the issue of stability of the M.2 and adapter solution its just not wise.
There was a point I was seeing one of these converted mac's every month only to tell the owner the drive had failed and I need to replace it with something better.
So, I personally don't recommend them, I would stick with either the custom Apple SSD or I would go with the OWC SSD.
If you had a MacBook Pro I would be more willing to go with the M.2 & adapter its at least easer to get to!
FYI: I love the Samsung SSD's most of the issue is in Apple's signaling system is unique and the adapters quality.
さんによる
Can I replace it with this without an adapter?
https://beetstech.com/product/sspolaris-...
さんによる
@duyjapan - Yes! Its a bit confusing! Apple contracted Samsung to make the custom drives.
The proprietary Apple NVMe/PCIe 3.0 x4 interface SSD you have linked ones not need any adapters.
It's a very good SSD for your system!
さんによる
コメントを追加
Maybe you use sata ssd to upgrade your imac
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
Duy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 41
今までの合計 2,779
