メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ハードドライブ(HDD)の修理情報。ハードドライブは磁気データ記憶装置です。低コストかつ高データ密度であることから、ほとんどのデスクトップ、ノートPC、サーバーで使用されています。
Fixing a clicking hard drive
Hi, so my rage got the best of me and I hit my computer. When I did hit it, nothing happened, nothing changed, as the OS and the game were installed on an SSD, continued playing as nothing happened. But I needed to restart my computer for something and it took really long time for it to boot up and it made strange noise. I take out the hard drive and everything’s fixed, tried using an enclosure and the result was the same, it made clicking noise and slowed down my computer to a snail and it wasn’t recognized. I know the chance of fixing is small, but I just wanted to know if there’s anything I can try to bring it back or something. I don’t have anything important on it, but additional 1TB hard drive wouldn’t hurt :D
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
If you can copy off anything of importance ASAP!
さんによる
コメントを追加
1 件の回答
ベストアンサー
That usually means the read heads in the hard drive are stuck from a drop or impact. It would require opening up the drive and using the proper procedure to undo a stuck reading head.
Problem with this is that it would compromise the dust-free enclosure inside and any dust that gets in the hard drive will cause the hard drive to fail quickly.
As it’s reading very slowly it’s most likely the reading heads are damaged and would require a read head swap (getting a identical read head with the right pre-amp is extremely hard to do and requires getting it from a identical donor drive as even the same model can have multiple different pre-amps depending on the manufacturer year and month).
TL:DR - There isn’t any way to repair thats cheaper and quicker than buying another hard drive.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Tomasz Videos さん、ありがとうございました!
統計データ:
過去 24時間: 16
過去 7 日: 96
過去 30 日: 420
今までの合計 9,815
