メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
住宅、オフィス、自動車で使用されるエアコンユニットの修理・トラブルシューティングガイド。
Stationary AirCon unit overheated compressor
Hi all. I'm new to the page and after some research I couldn't find similar topic/issue.
We have a floor standing unit Amcor 12000 BTU and after about a year of usage as aircon in summer occasionally and more often ad dehumidifier in winter it suddenly stopped blowong cold air.
They didn't accept it under warranty as apparently the “exhaust “ pipe wasnt lined up in less than 30 degrees to the unit which they said caused a compressor overheating. Unfortunately I wasnt aware of that and when they asked for a video and picture how the unit is positioned I didn't adjust it to meet the criteria so they have an evidence that it wasnt - my bad.
My question is, can this be fixed or I'm looking at purchasing new unit?
The unit cost was around 380GBP and they offered me a new unit deal for £250 plus this faulty one.
Many thanks for any help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Buy the new unit. it will be more cost effective for you.
Update (10/25/2021)
The discharge line can go any way you need, it , unless you used it on its side or upside down I think they are giving you a line of garbage. A compressor is cooled by the cold refrigerant gas coming from the evaporator coil , in an AC system the indoor coil is around 40 F and you typically do not want more than 10 degrees superheat about 1 foot after exiting the evaporator coil. The suction line should be “beer can cold” meaning it will condense moisture from the air onto its surfaces just like a cold can of beer does, this is how they de humidify as you discussed. I would try a capacitor rather than junk the thing, a run capacitor is about $10 and 2 terminals, very simple.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kamil Mandes さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 13
今までの合計 382
