メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
591回答 すべてを表示
What should I do with a swollen, removed laptop battery?
Hi there! Recently, I noticed the click on my MacBook trackpad wasn’t clicking so good! Once my laptop started randomly cutting out the power, I figured the battery was breaking. I have used an amazon replacement battery (will not make that mistake again).
So i removed it, and there was no visible swelling, but the trackpad worked well again.
My question is, due to the current situation, all waste recycling centres are closed, so I can’t dispose of it instantly. What would be the Safest way to store it until I can properly get rid of it?
currently it is inside a Tupperware, duct taped in a bin bag, in my garden. Is that (reasonably) safe?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi @wisteria
Just keeping it away from anything metal and anything sharp will render the battery harmless. As long as it’s charge isn’t affected by charging or discharging, it shouldn’t spontaneously light on fire (or cause any other type of harm). Even in these “worst case” environments, it’s extremely rare for a battery to light on fire.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the help
さんによる
コメントを追加
Put it outside or somewhere away from flammable items until it’s discharged! Think something like a area that’s mostly concrete - put it out there with the Tupperware cover you’re already using. Keep it somewhere a pet can’t get to it as well and you can safely dispose of it.
Seriously - TAKE IT OUT OF THE GARBAGE BAG! THAT WILL BURN EASILY!
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Keep it cool and out of direct sun as well.
さんによる
@danj The garbage bag is asking for trouble :-(. Future house fire.
さんによる
@nick - For sure! If you can set it afire its not safe!
さんによる
@danj If it was a minor bulge I could see inert house placement in glass, but we don't know. Best to keep it outside because we have to assume it's a ticking time bomb.
Even a plastic lid isn't great, but it's far less dangerous then a garbage bag.
さんによる
It’s in the garden and it has been the whole time- I was concerned about it getting wet inside the plastic box- it is raining here, heavily and I didn’t know if it was watertight. To be honest, I have a bare concrete garden and even if it did explode there’s nothing aside from brickwork for it to burn!
Thanks everyone for your concern.
さんによる
コメントを追加
回答を追加する
Wisteria Plant さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 115
