メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデルA1993。Apple Mac miniの2018年モデルです。プロセッサはオプションで3.6 GHz 4コアIntel Core i3、3.0 GHz 6コアIntel Core i5、および3.2 GHz 6コアIntel Core i7プロセッサから選べます。
Mac Mini RAM Upgrade Early 2020
Hey
Please don’t mind me asking - is it possible to upgrade the RAM in the new version of the Mac Mini from March 2020 as described for the 2018 Model? It would think so, but would like to make sure for my purchase.
Cheers
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 17
5 件のコメント
What are the specifications of memory on the MacMini 2020?
さんによる
@bknj - DDR4 PC4-21300 2666 MHz 260 pin SO-DIMM's (max of two DIMM's) Review this guide Mac mini Late 2018メモリ(RAM)の交換
さんによる
Thanks for the reply. Crazy how much Apple charges for RAM.
さんによる
Based off of images on Apple’s website for the Early 2020 Mac mini Overview and the statement on the he Apple Web site that the Mac Mini will use SO-DIMM RAM I would say yes, the memory is upgradable.
さんによる
Does anybody know is this memory compatible with mac mini 2020
Kingston Impact SO-DIMM 16GB DDR4 HX426S15IB2/16
さんによる
コメントを追加
4件の回答
最も参考になった回答
While Apples Mac Mini RAM guide implies its not upgradable Upgrade or install memory in your Mac mini
Both the 2018 & 2020 have serviceable RAM as seen here in this guide: Mac mini Late 2018メモリ(RAM)の交換.
Apple has only upgraded the CPU, RAM and Storage options in 2020 not altering the basic system design.
このアンサーは役に立ちましたか?
スコア 7
8 件のコメント:
I did one last month. 32GB Just make sure the RAM is fully seated so you don't have to open it twice like I did.
さんによる
Is the crucial ddr4 2666 32gb SODIMM the correct ram to instal in the Mac mini i7 2020? Iv been trying to find out for a while. Thanks
さんによる
Best to contact Crucial to ask them. Crucial
さんによる
Will Kingston Technology HyperX Impact 16GB 2666MHz DDR4 CL15 260-Pin SODIMM Laptop Memory (HX426S15IB2/16) be compatible with the mac mini 2020? I am thinking to buy one.
さんによる
On the market there are suitable memories with different speeds: 2666Mhz and also 3200Mhz. Does it make sense to use the 3200 Mhz ones on this Mac 2020 model?
さんによる
3件以上のコメントを表示
コメントを追加
Be aware you will be really disassembling the Mac Mini to get to the Ram slots. After you remove the black plastic cover and get to the Torx security screws be careful not to mix them as there are different sizes for the screws.
Finally when you go to insert the Ram take care to ensure the Ram is not inserted at an angle and is seated completely in the Ram slot. My roommate had to reopen his because one of the Ram cards wasn't fully seated in it's slot.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I did a RAM upgrade on a Mac Mini Late 2018. Take it slow and meticulously and make sure you follow the instructions. When you re-assemble the Mac, from the very first step when you insert the RAM and especially when you reconnect the cables make sure things are seated correctly and firm. I did not connect the fan perfectly and was greated with a very funny sound. It is very easy provided you have the correct screwdriver and good tweezers.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What are the mac mini 2020 SSD RAM upgrade options? How to do mac mini 2020 memory upgrade?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@shopinbrand
What your asking doesn’t make sense A ssd is a storage medium and ram memory is used for multitasking. If you haven’t taken a Mac mini 2020 apart make sure you are ready Have a sheet of paper and draw the mini out so you can lay the screws in the correct locations
As for what ram to buy it is clearly mentioned above several times You want good quality first run ram, NOT value ram you need 2666mhz sodim ram for the mini
さんによる
So the RAM in the new mac mini can be upgraded after purchase? I need to buy one now for work, and can't wait the 3-4 weeks for the delivery of the Mac Mini with 16GB.
さんによる
コメントを追加
回答を追加する
Lennart さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 53
今までの合計 55,339
