メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
CDMA 4G LTEセルラーネットワーク(Verizon)に対応した第4世代Apple iPad(16、32、64、または128GBストレージ)の修理ガイド、分解、トラブルシューティング情報です。2012年11月発売。モデル番号A1460で識別されます。
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I don’t know what I did different, but I got the display to work.
Thank you for the replies
さんによる
コメントを追加
3件の回答
最も参考になった回答
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sunruh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 402
