メインコンテンツにスキップ
2015年1月発売。XPS 13ラップトップは”見た目はボーダレスなインフィニティディスプレイ”を搭載し、タッチスクリーンへアップグレード可能な、MacBook Airと対抗するべく開発されました。
20回答 すべてを表示
iFixit Toolkit cannot open Dell XPS 13 9350 battery
I have bought "iFixit Pro Tech Toolkit - Electronics, Smartphone, Computer & Tablet Repair Kit" in order to change my XPS 13 9350 battery.
I successfully open the bottom case and able to open 2 screws at the right part of the battery.
But I could not open the 2 screws on the left part of the battery (please see attached file with circle in red color). I have tried all head styles of iFixit, but none can open the screws.
Appreciate any help. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
You don't seem to have uploaded an image so it's a little hard to tell, but according to the guide they should just be regular Phillips head screws. It's possible they got stripped if too much torque was applied, can you try uploading or linking an image again?
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Uups, sorry forgot to attach the picture, thanks for remind me.
I have used all the head screw styles, but none of it match.
さんによる
It's harder to tell for the one at the top but the bottom one is definitely stripped which is why you are probably having issues with it. But it is standard Phillips.
さんによる
The chassis will probably flex a bit when trying to unscrew those screws so I would say put opposite pressure under the screw under the chassis with your hand and use a PH00 / J00 or larger screw tip. Smaller ones will just cause it to strip.
さんによる
@cosmasaay - Can you take a tighter picture of the top Black screw.
It looks like a tri-point, you will likely need a Y0 or Y1 bit
さんによる
コメントを追加
The guide in step #7 is showing this as a small Phillips:
Dell XPS 13のバッテリーの交換
But if it id really stuck you may have to use extractor pliers.
Screw Extracting Pliers
Pliers designed to firmly grip the heads of damaged screws. Specially designed jaws firmly grip screw heads, bolts, or nuts allowing you to twist out even the most damaged fasteners. Professional Grade tool. ESD-safe option.の画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
these screws are FIRMLY Locktited in there. I can't break them loose. How do I release the Locktite?
さんによる
コメントを追加
回答を追加する
Cosmas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 653
