メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月にアップデートされたAppleの13インチMacBook Pro Retinaディスプレイモデル(A1502)は、第5世代のIntel Core i5およびi7プロセッサを搭載し、感圧タッチトラックパッドが導入されました。
Service Battery message still given after ifixit replacement
The “Service Battery” message is still be given in the battery drop-down menu after I replaced the battery with the iFixit kit. It seems like it was a successful installation other than that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
3件の回答
RESET SMC
MacBookでのSMCリセット作業
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Resetting the SMC is a temporary fix if the battery is faulty but good idea to try at least.
OP check the battery health with an application called coconut battery which can be downloaded online.
After SMC you may see the service battery message dissapear but reappear again if you drain the battery and charge it again indicating the system has found something wrong with the battery.
さんによる
I also replaced the battery with the iFixit kit. The SMC reset didn’t help, I still get the message: “Service Recommended”. Is it a fault with the battery delivered with the ifixit kit?
さんによる
Contact the iFixit store for a replacement.
さんによる
コメントを追加
This isn't a problem with the new battery, once the chip detects that the original battery has degraded past 80% (or so) or has started to rapidly degrade and inflate, the message will trigger and it's impossible to remove without paying for an official battery change from apple. This is obviously a way for apple to limit what people can fix and sell on (nobody will buy a phone with a "severely degraded battery message" even if the battery is effectively brand new and and 100%).
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
That is not true! you need to reset SMC fully to clear the set value. Or the battery is defective.
さんによる
So how do you do that ?
さんによる
@esnew -Did you follow the steps in the guide rustedchip pointed to just above?
さんによる
Im not sure where that is. Looking for rustedchip
さんによる
@esnew - Here’s the same URL link MacBookでのSMCリセット作業
さんによる
コメントを追加
Had a similar issue recently, tried two new batteries but service recommended message still present. Coconut Battery confirmed both new batteries were healthy. SMC Reset did not help but on a whim I tried an NVRAM Reset and bingo, message went away!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gregory Brunkalla さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 26
今までの合計 3,146
