メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
6.01インチのAMOLEDディスプレイを搭載したAndroidスマートフォン、OnePlus 5Tの修理ガイドとサポート情報です。2017年11月発売。OnePlus 5の後継機。モデル番号:A5010。
Oneplus 5T - Motherboard FPC pin Problem!
I've had this oneplus 5T where I cracked its screen(intentionally… /face-palm), tried fixing it myself, ended up in a total failure and this is how I ended up damaging the motherboard pin, where the USB cable connects.
Now I took a calm approach, and want to fix it again, I have all the necessary tools, but I have 0 soldering skills, so please check the images, and tell if it's possible, and give me some guides or something… thank you
画像
Here you can see the torn pin
画像
Torn part from the pin
画像
Here I cleaned up the area
画像
This is the new pin I've ordered
And here are the Tools I have
画像
画像
Is it possible to fix this??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
If someone have a dead oneplus 5t I would like to try to change this fpc connector practice make men perfect so if anyone have fully dead phone or motherboard issue let me know will try fix it. If it gets fixed it’s free for you.
さんによる 共有
have the same issue. Where have you found the parts..?.. which website you buy FPC connector..?
さんによる 共有
Hey were you able to fix it finally.
I screwed it up the same way.
Please mail me inorockdude@gmail.com. truly will appreciate it
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
100% That is possible to fix, practice in another phone for parts, if you purchased all that stuff you can purchase a phone for practicing. Until you do a clean job you can do it on your good phone.
With a Soldering pen with angle on the tip and enough flux you can do a good job.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
@conlledo This was my main phone 2 years ago, now I want to resurrect it, I've watched a lot of guides on this, and I will try and do it on this phone, with extreme patience.
I dont have have the Flux from my bag of tools but I've already ordered it, and also waiting for the pin to come, I will definitely give an update soon.
さんによる 共有
Find a board, any old board (Computer, Toy etc) and try to remove and put back components that helps to know your soldering pen. also does the soldering pen has temperature control?
さんによる 共有
That's a very good tip, and yes the soldering has a temperature control, 300 and something should be used from my understanding, no?
さんによる 共有
That you see the FPC is a plastic piece, and if the tip is too hot you can destroy it, so you have to choose the right temperature and right tip to complete the job.
さんによる 共有
Did it work out? I have the same issue. Where have you found the parts?
さんによる 共有
コメントを追加
I've had only problems with this phone, mine was never the same, I repaired it, I've sent it to oneplus for a trade in Programm and they never responded back…
To answer your question, I found it on a UK website but it costs 16£…
To give you a friendly advice, never settle.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
would you please provide me with the website that you got the FPC from? i am facing the same issue and couldnt find the chip. my email is bilal.haji@gmail.com
さんによる 共有
コメントを追加
Bro pin kaha se mile
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
aliexpress mein available ho
さんによる 共有
コメントを追加
回答を追加する
Macarovici Dan Andrei さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 47
今までの合計 2,227
