メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Moto E4 Plus(XT1774、XT1775、XT1776、または第4世代Moto E Plusとしても知られています)は、大型の5.5インチHDディスプレイと滑らかな金属デザインが特徴です。5000 mAhのバッテリー、撥水コーティング、指紋リーダーを搭載しています。
4G data not working
I’ve had my Moto E4 Plus for almost two years now and it’s been fine, but about two months ago my 4G data stopped working. It’s not like I have 3G all the time and just can’t connect to 4G, I just only have an internet connection when it is weak. For example, I can be downtown in a city and have nothing, but in the middle of the woods I’ll have a weak connection.
I’ve looked through my settings to see if there is anything that I may have pressed unknowingly, but after resetting to all of my original settings it is still a problem. I’ve also went into safety mode to see if an app I downloaded was blocking it, but that didn’t help either.
Does anyone know what could be wrong, and possibly a solution?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I have motorola noto e4,my cousin brought it from karachi ,he told me that it was connected to4g networks in Pakistan ,or simpky karachi ,but when he brought it kashmir, it stopped connecting to 4g network on every network sim ,there are many motorola phone which only connect 4g in pakistan,not in kashmir,kindly someone help ,me... Please
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
My device is not 4g working
My device 4G not working
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
IT IS JUST A PERSONAL EXPERIENCE — I was having the similar issue with a Customer after screen replacement, and after check Settings and a Factory Reset the problem persists. Opening the phone i saw one of 2 antennas was disconnected, put it in back fixed the issue.
can be something disconnected inside, a software issue and maybe is your carrier, a call can answer it, may they lower your data plan or something like that.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you for answering! I don't believe it is a carrier issue, my phone had to switch over to Boost Mobile since Sprint Forward no longer exists, and switching didn't solve the problem. Do you know if there is a way I can check to see if an antenna is disconnected on my own, or do you think I should bring it somewhere to be looked at?
さんによる 共有
If you dont feel comfortable taking apart your phone, a place named genius phone repair does free diagnostics for any issue
さんによる 共有
コメントを追加
my netwok is notgoing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sarah さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 15
今までの合計 2,355
