メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Coffee spill: Fully functional but shuts down when unplugged
I spilled coffee on my macbook causing it to not boot up from sleep. I then backed it up on an external hard drive while on external power. Now it functions normally except it dies as soon as it is unplugged from external power. The apple store said there was residual coffee stains inside and some liquid sensors were tripped but would not confirm a logic board or battery issue. They said it could be shipped off for $800 which wasn’t really worth it on a 5 year old laptop. I’m not sure if it is worth trying to replace just the battery or logic board or just update MacBooks. Attached is a coconut battery screenshot
. Any advice would be appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
First I’m not sure why you think its not worth it! Five year old cars still have a lot of life in them, why wouldn’t a laptop? I could see you out growing what it can do, I can also see the pangs of all of the new wiz-bang features of the newer models also pulling at you. But, only you know what your needs are. Your system still has more to offer!
So looking at CoconutBattery I see the charger is not charging your battery. So we knew you do have a logic board issue. Are you up to fixing your own system? Review this guide MacBook Pro 13" Retina Display Mid 2014の基板の交換 as well as MacBook Pro 13" Retina Display Mid 2014 の出入力ボードの交換. What we need to do is look a bit deeper for all of the spilled coffee and clean it up. You’ll want some distilled water and 85% or better isopropyl alcohol and some cotton swabs. Use the distilled water to wipe the areas you see and then go over them again with the alcohol. Take some pics of anything that looks off and post them here for us to see. Depending on what we find we might be able to get you going, at worse you may need a new logic board.
MacBook Pro 13" Retina Display Mid 2014 出入力ボードの画像
ガイド
難易度:
中レベル
45 minutes - 2 hours
MacBook Pro 13" Retina Display Mid 2014 基板の画像
ガイド
難易度:
中レベル
40 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jared C さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 119
