メインコンテンツにスキップ
Repair information for the Crusher Wireless headphones. Model number: S6CRW-K591. First available on Amazon in August of 2016.
24回答 すべてを表示
The turning mechanism between the earpad and the headband broke.
After almost one and half year my headphones just broke when I wanted to put them on. I was very surprised that this happened and I'm also very sad because I can't even wear them anymore. The sound and everything is just fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
4 件のコメント
Did you find a solution? I'm having the same problem and I'm looking for the replacement part to print it with the 3D print... But I can't find it...
さんによる
I duct taped it together until I got back home. (I was on an international internship). Then my dad gave me money to buy a new one.
さんによる
@Floortje B hahaha Ok thanks
さんによる
ok so I need the part that's still connected to the earmuff... the plastic piece with the 2 screws on the bottom of the first picture
さんによる
コメントを追加
3件の回答
最も参考になった回答
Floortje B  the only way you can fix that is by either having someone 3D print you a new part for it or you’ll find another pair that is broken other than the hinge part. Looks like the 2 screws are the only thing that hold those to your headphone. Removing those most likely enables you to replace the broken part.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
Alt for picture: https://imgur.com/a/TcRGRT2
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Great quick fix! If you find the time, create a step by step guide for this!
さんによる
@amber No time, this is what I got. It's pretty detailed already.
さんによる
コメントを追加
My device is broken exactly at the same point today. I fix it by drill a hole from one site to the other (1,2mm thick) and insert a steel pin (as it is used in watches). I used black tape to prevent fall out of the pin.
If anybody is 3D-printing original part, I would like to order one!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Floortje B さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 36
今までの合計 1,586
