メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
Getting S.M.A.R.T. errors on Apple SSD disk.
Hi,
I have this problem: My Fusion Drive in my Mac Mini Late 2012 is failing. I have S.M.A.R.T. errors on the Apple SSD drive.
So I have decided to upgrade to an 1TB SSD Samsung 860 QVO. But, I have many errors. I can't restore from TimeMachine and I can't reinstall from internet. On reboot I have crash.
So can you give any help? It seems that my Mac Mini is searching for 2HD (Fusion) and not only one... so gives me errors. Is there a solution?
Bye
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
First you need to put your system back to its original config with the HDD and the SSD installed. Then you will need to break the Fusion Drive set so you can take the drive out. Follow this guide Split Your Fusion Drive Apart
Once you’ve done that you can then reconfigure your drives.
Are you sure you’ve identified the correct drive? This system has two 2.5” drives which look the same! So make sure you’ve ID’ed the correct drive.
Mac mini Late 2012のハードドライブ交換 A common issue is the ribbon cables fail so you may not have a bad drive but a bad cable. That can explain your OS install errors.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you. I have Mojave on my macmini so your guide is not for me in all steps.
In Terminal i have to digit different commans to split my Fusion… but in general this answer solves the problem.
Bye
さんによる
コメントを追加
回答を追加する
fabio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 277
