メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nissan Altimaは、日産自動車が製造するミッドサイズセダンです。1957年に始まったNissan Bluebirdシリーズの系譜を継ぐモデルといえます。
Oil in spark plug well
So I went to do a tuneup on this Altima, oil was flooded inspark plug well, no smoke from exhaust.. or other tell tell signs of blown gasket
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The most likely cause for this issue is a bad valve cover. The gaskets that seal the spark plug wells/tubes are part of the valve covers. It appears you would need to get a new valve cover altogether in order to replace the seals for the spark plug wells. I always get a new valve cover gasket unless it is fairly new already and clean the sealing surfaces well before reassembly.
Looking at the cylinder heads online, the only other scenarios I can see or think of would be a cracked cylinder head or maybe a bad head gasket but it seems unlikely.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I had same problem and replaced valve cover which even though was plastic was over 100 bucks.
Still when I turn on car it has to burn oil in first cylinder every time.
I've been told it could be the spark plug tubes themselves or the seal at bottom of them.
I don't have presence of antifreeze or water in oil if that helps.
And the car runs well..
I still have this problem and now it tries stalling when sitting.
I'm not able to just throw money at the problem.
Doomed🤦
さんによる 共有
コメントを追加
回答を追加する
Stacey Savoie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 1,711
