メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Moto Z3 Playは2018年6月に発売されました。6インチの画面と、取り外しのできない3000 mAhのLi-ionバッテリーを搭載しています。リアカメラは12 MP、フロントカメラは8 MPです。モデル番号はXT1929-3、XT1929-4、XT1929-8です。 "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
Screen replacement causes digitizer to not work
We are a repair shop and we have tried replacing the screens on this model a few times xt1929-17 and every time the digitizer doesn’t respond on the new lcd has anyone experienced this issue or come up with a fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
コメントを追加
2件の回答
I am also experiencing this issue! The digitizer stops responding once you turn the phone off and then back on… it’s a little annoying to say the least. Any guidance on this would be awesome!
Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I’ve researched and asked local shops as well most have just blamed it on the current quality of the parts on the market being low. Are shop has suspended repairs at the time do to the large warranty rate of the XT models
さんによる
コメントを追加
You have to do a hard restart. It’s the only way I’ve found to do it.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Could you clarify how you did that? I had the battery cable disconnected, replaced the screen with no problem, and turned the phone on without issue. The problem is that the touch doesn't register, no matter how many times I fiddle with the battery. This was a straightforward, easy fix up until this point.
さんによる
When he says hard reset, he's likely referring to a factory reset.
I haven't replaced the screen on this device yet, but I plan to soon. I'll let you know if I run into this issue and have I might fix it.
さんによる
コメントを追加
回答を追加する
Mike Henry さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 1,313
