メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
328回答 すべてを表示
Data recovery and data transfer
Back in 2017 I installed an OWC Aura 6G SSD 480GB in my MacBook Air mid 2011.
Things were fine until last week when computer froze and is now locked so when I turn on, sign in, I get to desktop but cursor and trackpad do not work.
I may have way too much stuff on desktop. Now I contacted OWC to ask if they had an enclosure where I could put in their SSD and use it as an external drive at least to allow me to transfer data but they said they do not have that.
So I was wondering if there is any kind of adapter cable I could use that has USB capability that might allow me to connect the SSD (once removed from computer) and transfer data? Thanks for helping out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sounds like all you need is a new trackpad MacBook Air 13" (Mid 2011) Trackpad and here’s how to install it MacBook Air 13インチ Mid 2011のトラックパッドの交換
To double check plug in a USB mouse if that works then you should be able to save your system. In anywise you should then be able to backup your stuff to an external drive.
MacBook Air 13" (Mid 2011) Trackpadの画像
製品
$89.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Lore さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 49
