メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ジャンプ・ドライブ、USBスティック、サムドライブとしても知られるUSBフラッシュドライブの修理ガイドとサポート。
Why is my USB device not recognized?
The system of my computer is Windows 10. When I plugged in my USB hard drive it just doesn’t turn out and shows that "USB device not recognized". I have upgraded all the drivers. They are up to date but still not working. What can I do with it?
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
ベストアンサー
Hi, can you check the USB device from the Disk Management?
Way to check with these steps:
  1. Press Win Logo key + R and then type: Diskmgmt.msc
  2. Find your USB device there.
Give me the feedback, thanks.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I have followed the suggestion and the device can be found already. Thanks a lot!
さんによる
Hi, if you can find the USB device there in Disk Management, that means the device is still working but corrupted due to some technical reasons. To fix this error, you can try to retrieve the data first from the USB device and then follow the steps with this link to fix: https://www.r-datarecovery.com/usb-devic..., leave me the feedback here, thanks.
さんによる
I've fixed the problem with your suggestion. The software is so convenient to use. Thanks a lot!
さんによる
コメントを追加
Try shutting down Windows from the Start Menu.
When shut down unplug the computer for about 5 minutes.
Plug back in and turn on.
Now try plugging in the USB device and see if it is recognised.
Let me know if it works.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank u for your advice but the problem still remains :(
さんによる
コメントを追加
Hi @jityvub
Had you tried on another computer and another USB port?
You mentioned it is a USB hard drive. Do you have model no of it?
When you connect the drive to your computer, I presume it is a mechanical HDD, do you hear any weird sounds coming out from the hard drive? e.g. some tick tick or motor spin and stop abruptly?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
It is just a common USB flash disk.I've changed the other USB port and I can find the weird sounds but the error remains. I only have one computer can be used at this stage.
さんによる
no matter what... if data is important, if it can still be access, copy it out.
さんによる
コメントを追加
回答を追加する
lozemyti さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 31
今までの合計 2,595
