How do you open the mouse
Like the questions says.. My scroll wheel has come loose
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try following this guide to open up your mouse.
このアンサーは役に立ちましたか?
Tks! M280 is same model.
Thanks.. a very useful guide..
Thanks for the guide, been looking for some time, and finally found it. Will try out the steps over the weekend.
Is it possible to remove the scrolling wheel spring? It's so noisy and beat the "silent plus" branding. I did this to all my previous logitech mice but seeing the photos above, it seems that there's no "metal" spring but a black plastic spring instead. Can you confirm? Thanks!
Thanks man
my left click now worked again, just clean it use contact cleaner.
in the answer provided by @arthurshi , I want to add three points:
In the picture, 4 notches were already highlighted with blue circles, but these 4 do not get locked. There are 3 more notches, in green, which gets locked when mouse is closed.
1) There is a hole provided to insert a pin/screw driver, in green down arrow, & gently press the lever to the left, 1st yellow direction.
With this the lower portion of mouse will get detached.
2) then, we have to genlty slide the lower case to forward, 2nd yellow direction. For some reason this direction was wrongly mentioned in original answer.
3) Reverse process should be followed to lock the top two notches while assembling the mouse.
このアンサーは役に立ちましたか?
Thanks for the guide bro, been looking for some time, and finally found it..
ecd, thanks for the addendum instructions
過去 24時間: 2
過去 7 日: 19
過去 30 日: 39
今までの合計 9,245
